Shaking after 75mph
Old Oct 30, 2005 | 03:06 PM
cccp's Avatar
Shaking after 75mph
Hey everyone my runner starts to shake after or whenever i hit 75mph. What can be the cause? Can it be my alightment?
Old Oct 30, 2005 | 03:10 PM
ChickenLover's Avatar
Sure. Could also be unbalanced tires, improperly inflated tires, worn steering components (tie rod ends, ball joints, idler arm). An after-market steering stabilizer always helps too.
Old Oct 30, 2005 | 03:11 PM
bob200587's Avatar
could be that, could have a tire thats a little off from the rest (pressure), maybe some other stuff....I have the solution tho, don't go 75...go 70 or 65. You'll get better mileage thats for sure.
Old Oct 30, 2005 | 03:27 PM
Dublin's Avatar
Play a little Eddie Money next time... "she was shaking..."
Old Oct 30, 2005 | 03:38 PM
ebelen1's Avatar
If it's only within a certain speed range, it could be balancing of your tires. I had a similar issue awhile back when driving 60-70 mph; it turned out to be the balancing. Some places do a high-speed balance. This is not cheap and costs around $50 for all tires.
Old Oct 30, 2005 | 04:14 PM
4runnerx4's Avatar
Check your shocks also you could have a rear tire bounce.
Old Oct 30, 2005 | 04:25 PM
Fink's Avatar
Start with the small stuff, check tire pressure, get wheels balanced and rotated while you're at it and then go from there. If it still does it after all of that, make sure it wasn't just the part of the highway you were on, there is a 2-3 miles stretch around here that has some serious bumps and stuff and it shakes, rattles and rolls all the time when I'm on it. Not to make you sound stupid, but a lot of the time you just don't think about it.
Fink
nvwiggins
13
Jun 16, 2016 03:05 PM
stoneboy91
Apr 5, 2016 05:17 PM
calderp
Nov 16, 2015 02:49 AM
BK2TFUTURE
Oct 11, 2015 08:42 PM
izzmee
Aug 17, 2015 10:20 AM
