Info on oil filter relocation kits
Old Oct 30, 2005 | 07:45 AM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
Info wanted on oil filter relocation kits
Having to pull the front skid plate off my 3rd gen is a bigger PITA than it was on my 2nd gen and, even with extended oil change frequencies with synthetic, I'm still changing my oil filter almost every 2 months. I'm considering a relocation kit.
I've seen the Perma-Cool relocation kit in the P.P. catalog for $59.95.
  1. Are there better kits out there?
  2. Is that a decent price?
  3. Where is a good place to mount the filter?
  4. Did you change to a larger filter?
Old Oct 30, 2005 | 08:44 AM
MarkieMark's Avatar
I also need an oil relocation kit. Just to make life easier
Old Oct 30, 2005 | 08:57 AM
dwh91102's Avatar
https://www.yotatech.com/~corey/tech...msoil/tbob.htm
this is something close to give you guys some ideas, also try the search button I know theres some others on here
Old Oct 30, 2005 | 09:05 AM
Bob_98SR5's Avatar
heres what i did:
http://www.4runners.org/articles/permacool
guys, you really need to search. there is a lot of info you can find by just using the same words in your questions
bob
Old Oct 30, 2005 | 12:37 PM
kyle_22r's Avatar
as a rule of thumb, anything that'll work on a ford engine will work for a toyota one. i use a wix 1515 filter for my engines, which is a ford FL1A filter.
Old Oct 30, 2005 | 02:11 PM
Rick F.'s Avatar
Thanks, guys. Are the Perma-Cool kit's hoses long enough to mount at a suitable place in the 3.4L 3rd gen or sould I assume I'll be modifying it with longer hoses? The add in the P.P. catalog states that it adds almost a quart to your oil capacity. Since it doesn't come with a filter, I assume thats the oil volume in the additional hose supplied with the kit.
Old Oct 30, 2005 | 05:03 PM
2000t4r's Avatar
I didn't want to mess with the PP kit so I just ordered the spin on adapter and filter relocation part that are used in the PP kit, and used my own fittings and hoses. It was a hole lot cheaper than the PP kit.
bigjstang
Jun 2, 2025 03:56 PM
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
