What size Rims for 32x11.5 R15
Old Oct 31, 2005 | 08:17 AM
hill's Avatar
Ive heard rumor that stock rims from a 2nd Gen (7" R15) are too small for 32x11.5 tires.
What is a better size? 8"? 7.5? 9?
Cheers
Old Oct 31, 2005 | 08:25 AM
westy44runner's Avatar
I have 32x11.5 BFG Muds on stock 7" 4runner rims and they are fine. You will not have any problems...
Old Oct 31, 2005 | 08:46 AM
Racer944's Avatar
it's recommended that you stay within 4 inches of the tire width, so the prefered methodis to upgrade to 8 inch wide rims, however, as westy is stating from experience, it will still work with stock 7's
Old Oct 31, 2005 | 08:54 AM
ToyoRunner94's Avatar
7" stockers will work just fine. i run 33x12.5 on 8" rims. going up one size from 31's wont pose that much of a threat. save your cash for something else, tear up those stockers first.
Old Oct 31, 2005 | 09:10 AM
Cebby's Avatar
I ran the stock 7" alloys for two sets of 32 x 11 BFG AT's. Make sure you rotate routinely. Mine had a tendency to get some odd wear on the outside of the front tires - although this was due in a big part to a bad alignment or two.
Old Nov 2, 2005 | 05:48 AM
hill's Avatar
thanks, i was worried about having to go to black steel wheels....PHEW...ha ha ha...
maybe ill invest in a good alignment.
and god dam i gotta find a welder to tack up these sliders.
Old Nov 2, 2005 | 06:22 AM
jacksonpt's Avatar
Senior Member
I ran 32/12.5-15s on stock 7" rims for a long time (about 45k miles, on road and off) with no problems.
Old Nov 2, 2005 | 07:23 AM
4Crawler's Avatar
Shold be no problem on 7" rims, although you may have to shop around for a tire shop to mount them. I run 33x10.50s on my stock 6" rims (same width difference) and they work great, air down nice off-road and aired up the are decent on the road. You have to work on finding a good pressure to run on the road.
Old Nov 15, 2005 | 05:51 PM
calg3's Avatar
I have run my 32" BFG AT's for many miles on my stock 15x7 rims at 25 psi with no problems.
Old Sep 10, 2009 | 03:33 PM
Slowrunnin's Avatar
I have 32x11.50xR15 on my 92 stock rims with no problems!
Old Sep 10, 2009 | 07:41 PM
B. Graves's Avatar
can you run a 10" wide wheel with 32x11.50s without problems?
smilen724
13
Nov 8, 2015 04:11 PM
Cycles
Sep 29, 2015 06:37 AM
oldblue
Sep 28, 2015 04:07 PM
gp66
Sep 14, 2015 12:10 AM
Gravel Maker
RuffStuff
Sep 8, 2015 05:46 AM
