Siping Tires in Desert Climates?
Old Oct 24, 2005 | 10:06 AM
4Runna's Avatar
Anyone here that lives in AZ, NV, NM or any hot/arid climate sipe their tires? Does it offer any advantages in our climate?
Not too much snow here in Las Vegas in the wintertime...
Old Oct 24, 2005 | 11:57 AM
X-AWDriver's Avatar
No and driving on alot of dry roads including dirt might tear at the sipes. IMO it would be a waste in Vegas.
Old Oct 24, 2005 | 12:14 PM
Albuquerque Jim's Avatar
It actually helps a lot. It keeps the tires cooler which extends tread life. It also works well if you wheel in the rocks.
Old Oct 24, 2005 | 01:11 PM
4Runna's Avatar
I would also think that dry hot roads would quickly deteriorate siped tires. But AJ, if you're having good results I might take a look at it.
Actually, I'm waiting until these tires wear out so I can put some Goodyear or BFG M/T tires on...
Old Oct 25, 2005 | 04:05 AM
KZN185W's Avatar
Pardon my ignorance, but what is siping and how is it done?
Thanks a lot!
Old Oct 25, 2005 | 05:45 AM
99_Runner's Avatar
Siping is basically where they cut lines into the tire. It gives your more biting edges and is supposed to help with snow and ice traction mainly.
Old Oct 25, 2005 | 06:08 AM
Unhappy99's Avatar
Buy a good tire to begin with.
Old Oct 25, 2005 | 08:38 AM
4Runna's Avatar
I have Bridgestone Dueler A/T Revos aka the Yotatech standard issue tires...
Old Oct 25, 2005 | 09:06 AM
IMO, the Revo has enough siping to begin with. I don't see it helping much.
Additional siping is mostly beneficial with an agressive MT or a Swamper because they do not come with any type of siping, just large lugs.
Siping Article
Old Oct 25, 2005 | 09:11 AM
deathrunner's Avatar
I had a chance to watch Goodyear, Toyo, and BFG siping tires at the CORR event held down here. It was fascinating, but looks like a chimp with a hot knife could do it. It seems like siping the right pattern just comes from trying it enough times. If only I had that much money to blow on tires
They have basically a really hot 1/4"-1/2" wide blade that they set the depth on and just gouge sections of the lugs out. It took them abou 10-15 minutes per tire and they had 4-6 guys doing it at each booth. There were enough rubber chunks laying around that I thought about collecting them and retreading my AT's when they wear down
Pretty interesting and I'm sure beneficial, but definitely moreso on aggresively treaded tires.
Old Oct 25, 2005 | 09:28 AM
4Crawler's Avatar
I sipe all my MT tires, no need for any special tools outside a utility knife:
- http://www.4crawler.com/4x4/CheapTri...reSiping.shtml
I find it helps traction on rocks, on wet pavement and of course on snow and ice. As mentioned, siping helps the tread run cooler and is supposed to make it last longer. If done right (keep siping away from the ends of the tread lugs), no problems with chunking or unusual wear.
DeathCougar
Apr 1, 2018 11:29 PM
RammerX
Aug 29, 2015 01:10 AM
mr_manny
Jul 31, 2015 10:39 AM
DrZero
18
Jul 24, 2015 11:31 PM
daddio
Jul 18, 2015 10:20 AM
