'04 Tacoma 4 cyl - plastic material blowing out defrost vent area ?
Old Sep 14, 2007 | 11:31 AM
Mike Murrell's Avatar
'04 Tacoma - 2.4l motor - automatic - baseline truck.
This has been going on for a long time and I've never been too oncetrned about it. Thought I'd check here to see if anyone has experienced this.
All along the top of the dash I will see very small pieces of clear plastic-like wrapping material. It looks like the clear plastic used in a lot of shrink wrapping. I suspect there are components inside the dash area wrapped in something like this and it's coming loose and blowing up through the defrost vent area.
Occurs of course when I turn on the a/c and I do have the vents directed at me and not the windshield. There isn't a ton of the stuff blowing out, but after I wash the truck and clean off the dash, a day or 2 later, I'll see a dozen or so very small pieces of this clear plastic-like wrapping material scattered over the top of the dash.
Anyone else experienced this?
I did check the library site here for TSBs. Nothing related to this popped up.
Thanks.
Old Sep 14, 2007 | 11:43 AM
OSU4Runner's Avatar
You might have sucked something into the fresh air intake and shredded it in the fan or could have been a nest built in there.
Old Sep 19, 2007 | 03:45 PM
Turns out there are foam pieces under that dash with plastic backing behind the foam. Flakes off.
MO transplant
Apr 23, 2023 11:58 AM
dumpster84
Apr 30, 2016 06:03 AM
HookahRoo
Jul 20, 2015 07:06 PM
94whiterunner
Jul 12, 2015 07:15 PM
elwood73
Jul 5, 2015 07:07 AM
