120,000 service
Old Aug 30, 2007 | 02:56 PM
FORANA's Avatar
120,000 service
I couldn't find info on this can you guys help?
I am about to hit 120,000 miles. What should I have serviced? Any links to this? I read the service schedule by toyota, should I do anything else? Someone said I should change the timing belt and if I'm changing that then I should do the water pump too.
Thanks!
Old Aug 30, 2007 | 03:56 PM
Skrillah's Avatar
Search! But yes, if you have the 3.4 L, it is most definitely time to have the timing belt changed, the water pump will be off while they're doing that service so yes go ahead and have them replace that then too.
Depending on the shape of the vehicle and the previous owner, I'd say check everything. It doesn't hurt, if you don't know whats been done, then do it as a safety measure. Check plugs, air filters, fuel filters, gear oils, oil, plug wires, etc. etc. Again it just depends on the vehicles past. More info on your rig is needed. Visit www.4runners.org...its a great how to website or visit the tech/maint. sections here on YT.
Dale Johnston
11
Oct 31, 2015 10:22 PM
Boomer8404
Sep 24, 2015 01:12 PM
Boomer8404
Sep 20, 2015 06:15 PM
Kytowboater
Sep 17, 2015 11:17 AM
mirabile4runner
Sep 3, 2015 07:15 AM
