Neeed Help
Old Sep 6, 2007 | 07:29 PM
Kerby J's Avatar
Question Neeed Help
hey guys i ned some major help with my 3rd gen 4runner, the other day i was startin to put on my lift when i came to a major roadblock. i had it up on jack stands with the tires off and took the bolt off that connects the upper controle arm to the steering knuckle and then i could not get the upper controle arm off at all it wouldnt budge i even took a hammer to it as a last resort. does anyone know of a way that i could get it off? anny suggestions would be much appreciated thanx guys
Old Sep 6, 2007 | 08:59 PM
nc994run's Avatar
From: raleigh, nc for school chapel hill, nc for home
Shouldn't you be unbolting the lower control arm instead of the upper? That's the way I've done it in the past
Old Sep 7, 2007 | 02:34 PM
Kerby J's Avatar
i might try that thanx for the info i was jus wonderin if there was a way around it caus ei really didnt want to do that but if i have to i guess i will
Old Sep 7, 2007 | 02:41 PM
frodin1's Avatar
What are you installing? What kind of lift? Need more info?????
Old Sep 7, 2007 | 10:03 PM
Kerby J's Avatar
Re
o its a revtek 3 in lift but im only doin the spacer up front for right now cause when i get all my parts for the asin hub swap im doin bout a total of 4 in
Garth schafluetzel
Sep 2, 2010 09:25 PM
azdirtdemon
3.4 Swaps
11
Aug 14, 2010 07:28 PM
brent4R
Jul 7, 2010 10:36 PM
Irish93
Aug 30, 2009 06:47 PM
lilgreg46
Apr 7, 2009 07:13 PM
