southern utah wiring help
Old Aug 6, 2010 | 09:50 AM
azdirtdemon's Avatar
probably not the right place for this so delete as necessary.. im doin the 3.4 swap into a 93 manual and got myself into a bit of a bind and neeed some wiring help. if theres anyone close to st. george that would be willing to help me out, maybe look it over i would make it worth there while to them. much thanks
Old Aug 8, 2010 | 08:04 PM
sam4runner's Avatar
bummer man, i just moved to Salt Lake like two weeks ago. I have completed my swap and did all my wiring myself. I might be coming down there this weekend though. I am not sure yet
Old Aug 9, 2010 | 07:06 AM
dang well lemme know if you do i could sure use some insight and any help is good help. if i get too stuck ill post more questions on here i guess too
Old Aug 9, 2010 | 09:50 AM
yodathespian87's Avatar
What are the exacts of the swap you are doing? I just got my 93 4runner running and the engine is a 2001 tacoma. I have a wiring helper thread open already. Which has diagrams that work. If you have any questions feel free to ask. To bad I'm not closer, I used to drive through St. George all the time going to Cedar city.
Old Aug 9, 2010 | 11:15 AM
donor 3.4 is a 97 4runner 5speed 4x4, recipient is a 93 pickup 5speed 4x4. i bought the whole runner after a roll, which happened to be the only time it'd been offroad i think. and i haven't thrown any of it away feering id neeed something else off it. the truck is actually in kanab but im more than willing to drive to stg. and probably cedar for help. wiring worries me ive popped a computer before and it stresses me out pretty good.
Old Aug 9, 2010 | 12:09 PM
https://www.yotatech.com/forums/f160...thread-206686/
Here is the thread. All you are doing is splicing the dash and body harness to the 3.4 engine harness. Great to hear you have the entire vehicle to pull from. There are plenty of little parts that you end up needing.
Old Aug 10, 2010 | 08:10 AM
thanks that should help a lot but one more question. what is to be done with the alternater wiring? i assume i use the truck side for the big white wire but what about the three wire plug? do i use the 3.4 or the 3.0 harness thats built into tthe trucks harness?
Old Aug 10, 2010 | 12:20 PM
I used all the 3.4 engine accessories. Alt,power steering, EVAP canister. Stuff like that. I felt is was better for future parts replacement. Use the 3.4 alt. harness and keep it with the 3.4 engine harness. Seeing as its all there, and plugs into the 3.4 Alt.
Old Aug 10, 2010 | 12:27 PM
so can i just cap offthe truck alt harness then?
Old Aug 10, 2010 | 01:54 PM
Cap off? You can cut it off. The thing is you are removing anything that was 3.0 engine harness and you are replacing that with a 3.4 harness. You will want to also sign up for the Toyota diagram site. TIS and pay the money to download all the stuff you can for your vehicles both of them. Then go over these diagrams till you are familiar with the parts that you are swapping in and the wires that correspond with them.
Old Aug 10, 2010 | 02:19 PM
hamish_18's Avatar
I used the 3.0 alt, as it fits the same as the 3.4 except for slight modification to the lower bracket. Which I believe is mostly due to the bracket being so close to the steering rod. Then you just use your stock wiring. And that is it..
Old Aug 14, 2010 | 07:28 PM
oooh yeeaa!! it runs!! somethings not right with the fuel pump though i gotta power it up with the power probe but once i do that it starts right up!! im assuming something with the COR??
80Truck
Oct 12, 2025 07:25 PM
shisha1999
Mar 16, 2016 12:25 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
Daneums
Jul 28, 2015 11:57 AM
