My engine makes a bad sound (video)
Old Nov 3, 2008 | 05:57 PM
Yukon's Avatar
So this started a bit ago, and I've just used the jeep driver method of fixing things, turn the radio up and ignore, but now its time to try and troubleshoot.
Here are videos
It doesn't sound like it is coming from the fan, seems like its coming from the left side Facing the car so like the air intake side.
Anyone have any ideas? I'm probably taking it to a shop to get their opinion, but dont want to go in blind
thanks guys!
Old Nov 3, 2008 | 06:09 PM
SoCalPaul's Avatar
Damn, sound's bad (expensive). Maybe the cam bearings or valves.
Good luck,
Paul
Old Nov 3, 2008 | 06:22 PM
Maj's Avatar
Maj
Kinda hard to tell from just that video but I'm guessing it is a belt-driven accessory. Power steering pump, alternator or A/C would be my guess. Let some mechanics give it a listen and they can probably narrow it down for you.
Old Nov 3, 2008 | 06:29 PM
SchooBaka's Avatar
Check you're power steering fluid.
Sounds right and in the right vicinity.
Old Nov 3, 2008 | 06:33 PM
danimal92sport's Avatar
Pull the accessory belts one-by-one and restart the engine in between to listen for a change. I agree with the above poster, it sounds like a PS pump that is low on fluid.
Old Nov 3, 2008 | 06:37 PM
Yukon's Avatar
Checked power steering fluid, and it checks out OK
It does it with and without the climate control on
Though i should add, it is a dark color, almost dirty oil color, and it looks like it leaks out just a little as there is oily residue on the reservoir thing.
Old Nov 3, 2008 | 06:38 PM
Yukon's Avatar
I have no idea how to do this To be honest. I also have a college parking lot as a workshop, and basically some sockets to do it with. Anyone have a step by step? I'll do it if i have an idea what I'm doing.
Thanks for the help so far guys!
EDIT: did a search, and looks like its not that hard, estimates on time?
Old Nov 3, 2008 | 08:55 PM
warriors_03's Avatar
I have to agree, that wound earily like my moms jeep when the PS pump was going out...
Old Nov 3, 2008 | 09:50 PM
drew303's Avatar
I'd back the idea its something on the belt system, pulley, power steering something... Doesnt sound like an internal type noise.
Old Nov 4, 2008 | 03:04 AM
racermp's Avatar
sounds like power steering, maybe the fluid or pump bearing. doesn't sound like an engine problem sound.
Old Nov 4, 2008 | 09:46 AM
runner00's Avatar
You can use a long screwdriver as a stethoscope to find the problem, just put the metal end on the part, your ear to the handle, sounds silly but it works.
Old Nov 4, 2008 | 10:15 AM
Yukon's Avatar
Thanks for the reply's guys, Going to go out and take the belt off and see how it sounds when I'm done with class. Hopefully I can get it diagnosed and fixed by tomorrow, because after that it goes from 60's to 30's and rain.
Old Nov 4, 2008 | 03:56 PM
Yukon's Avatar
It was the A/C compressor Idler pulley, loosened it up, and it stopped making the sound. Going to replace it over thanksgiving.
Old Nov 4, 2008 | 04:33 PM
bwhyit's Avatar
Sounds like a timing belt tensioner or water pump. Hard to say without taking the accessory drive belts off first.
Old Nov 4, 2008 | 04:55 PM
racermp's Avatar
get a car stethoscope (cheap) from a auto parts store and start touching it to the ps pump, timing belt coverr, etc and see where it's the loudest. easiest way. i sitll think it's the ps pump
arlindsay1992
Jan 23, 2024 01:34 PM
puddlepirate
Jun 30, 2015 05:08 PM
serenity03k64
Jun 27, 2015 07:59 AM
WI Girl
Jun 25, 2015 03:45 AM
Mr.Black
Jun 21, 2015 10:17 AM
