99 Limited Push button 4wd issue
Old Oct 27, 2008 | 06:58 PM
Yukon's Avatar
In my 99 Limited, with the AWD push button option, the AWD wont engage while im moving, well sometimes it will, but with no predictability. It will engage most of the time if I put it in park before I push the button. Other times it will just flash at me until I turn it off.
Funny thing is, it drives like its in 4wd when its flashing while driving, it just wont turn solid. I don't have a problem ever when pulling the lever, just the button while moving.
Does this happen to others? I know you can't turn it on above 62, but other than that I can't figure it out. Its not vital, just annoying to have to come to a stop, shift into park, then wait then drive.
Any ideas what I should take a look at? Hoping to get this solved if its not too involved, before everything is snow covered.
Thanks!
Old Oct 27, 2008 | 07:09 PM
Dan.3's Avatar
99 didnt have a push button 4wheel drive. does this button happen to be on the left side of the steering wheel?
Old Oct 27, 2008 | 07:11 PM
Spence1016's Avatar
im pretty sure they do have push button awd, only on the limited's though
Old Oct 27, 2008 | 07:15 PM
Yukon's Avatar
Its multi-mode
You have 2Hi, AWD Button (on road open center), pull back 4hi lock center, then 4lo
Dan.3's Avatar
you know this how? its not the RR button is it?
Old Oct 27, 2008 | 07:17 PM
Yukon's Avatar
you know this how?
http://www.hunt4steve.com/99RunLtdDT.html#Xcase
No no the RR button, or the center lock button
Old Oct 27, 2008 | 07:28 PM
Dan.3's Avatar
wow very interesting. i wonder how rare this is I have seen a few 99 limited but never saw that. could possibly be a solenoid issue. try hooking up a diagnostic computer to it. The flashing light can be an error code.
Old Oct 27, 2008 | 07:37 PM
SharpStick's Avatar
Ehh, I just drove a '99 Limited with push-button four-by high. Don't know much about it, but I know it was there, on the left side of the transfer-case knob.
STICK
Old Oct 27, 2008 | 08:23 PM
Godzilla's Avatar
Any 99 limited with 4wd will have the multi-mode 4WD. Yukon, many people have had this problem and I have attached a link to one of the better threads, however I will encourage you to search as this has been a frequently discussed topic.
https://www.yotatech.com/forums/f2/4...er-ltd-131201/
Old Oct 27, 2008 | 08:25 PM
Godzilla's Avatar
actually it looks like your problem may be solved on page 2. #29, 31 and 35
Old Oct 27, 2008 | 08:32 PM
stagger_lee's Avatar
Thanks for the link Godzilla! I will be able to help my dad fix his now before first snowboard run up the mountain! You the man! Cheers!
djpg2000
Nov 11, 2020 04:56 AM
jasonty
41
Dec 23, 2018 01:00 PM
mskalmus
May 28, 2017 07:51 AM
msane99
Jul 11, 2015 08:08 PM
Coreyr384
Jul 10, 2015 11:13 AM
