Check engine light turned off?
Old Nov 7, 2008 | 11:36 AM
Doddy's Avatar
I bought my 2000 4Runner about 7 months ago, and three days after I had it the check engine light came on. It was tripping a lean code so I assumed I had a bad O2 sensor but the code reader wouldn't give me any info as to which bank was tripping the sensor.
Anyway, I never got around to fixing the problem and then about 3 days ago all the sudden the check engine light turned off. I thought maybe it burnt out, but when I turn on my ignition it lights up.
The only thing that I have done in the last month is run some Seafoam through the engine, and clean the MAF sensor. I did the Seafoam about a month ago, and the MAF about 2 weeks ago, but there were no imediate results. Do you think that this may have fixed the problem? I wasn't getting the best gas millage before, about 15-16.5 and I haven't been able to see if that went up at all.
Do you think that the problem could have just fixed itself?
Old Nov 7, 2008 | 11:49 AM
DailyDrive's Avatar
Yes, the check engine light can go away by itself. The code should still be stored though.
Old Nov 7, 2008 | 11:53 AM
bwhyit's Avatar
Well, you've only got 2 O2 sensors (1 pre and 1 post Cat) so you wouldn't have a lean code on an individual bank.
It's a good possibility you fixed your problem when you cleaned your MAF. It's a fairly common problem on these vehicles. Probably more common than an O2 sensor would be.
I'f I were you I'd judt keep driving it and wait to see if the light comes back on. If not then don't worry about it.
Old Nov 7, 2008 | 12:09 PM
Jay204's Avatar
Weird..samething happend to me recently. Mine was on for a few days then went away....i'm thinking its likely my O2 sensor seeing on how i'm getting worse mpg suddenly or maybe its the cold weather? Wish I had a scan guage :sigh:
sonic concepts
Aug 16, 2025 03:13 PM
rbravo1
Jun 29, 2015 01:34 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
94hiluxZE
Jun 22, 2015 10:42 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
