RR Diff Locker on a 99 4runner not engaging
Old Jan 14, 2010 | 03:31 PM
Smallwood0507's Avatar
Alright so my 4runner has a RR Diff locker on it and i havent needed it since i bought my car tell last weekend and for the life of me i couldnt get it to engage it just sits their and blinks for ever and the ABS light comes on. Wondering if their is a trick or if you think its shot?
Old Jan 14, 2010 | 03:51 PM
nc994run's Avatar
From: raleigh, nc for school chapel hill, nc for home
Were you in 4x4 Low when you tried to turn it on? Have you done the gray wire mod?
Old Jan 14, 2010 | 04:22 PM
neoworm0's Avatar
If you don't use them they tend to sieze up.
Old Jan 14, 2010 | 05:38 PM
team_gforce's Avatar
Also, try going forward/backward very slowly with the steering wheel turned to allow the teeth on the locker to line up and engage, it is a very noticeable "click" when it finally engages. sometimes they can be very stubborn
Old Jan 15, 2010 | 04:55 AM
BigBallsMcFalls's Avatar
try it in 4wd lo, on dry flat pavement, turning in a tight circle about 4 feet, slowly, then
stop, reverse, and turn the wheel a different way, then do it straight...very slowly.
keep trying, it should eventually KLANG right in.
keep at it. go back and forth slowly, straight for a bunch of times. punch the button a few times.
when they were brand new in 1999, they seem almost stuck and hard to use. ya gotta use it often to make it engage all the time. loosen it up
if it has never been used, it could be seized, or need a persuader
Old Jan 15, 2010 | 06:43 AM
fireball's Avatar
Is this the officially recognized testing procedure to make sure the diff lock is working properly? When I was looking for my truck I test drove a few with the lock and wasn't sure if there was a way to test it for proper operation.
No offense, but this seems a little less than exact!
Old Jan 15, 2010 | 07:23 AM
nc994run's Avatar
There is no "officially recognized testing procedure", just the most common way to get it to lock in. My e-locker goes right in, no going forward or backwards needed,but that's because I turn it on and off once or twice a month. Regular use is the best way to keep it working.
Old Jan 15, 2010 | 08:02 AM
DeathCougar's Avatar
Abs light is supposed to come on, because with the locker engaged the system disables the ABS.
Old Jan 15, 2010 | 02:29 PM
The locker is a very simple device. All this procedure is designed to do provide differential action the locker. The gears need to line up just right to be able to "lock in"
Simple device = simple procedure
Old Jan 15, 2010 | 05:03 PM
fireball's Avatar
Cool, thanks for the info. As I said I don't have one on my truck and only drove 2 that did have them and didn't bother testing it out b/c I knew I wasn't going to buy them.
Regarding simple devices, there's nothing wrong with the KISS theory!
Old Jan 16, 2010 | 08:51 AM
Thanks, Finally got it to click in yesterday after driving in slow circles of a while .
Jun 1, 2021 01:51 PM
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
A2theK
Jul 12, 2015 10:46 AM
AaronM
Jul 8, 2015 07:15 PM
