Rough idle/random misfires (I am frustrated)
99 4runner SR5 4x4 144k miles
6 cyl
Colorado location in case this matters.
Started to run poorly last summer. Check engine light came on
Cleaned the MAF Ran great and light would actually go off from time to time.
Fast forward a year later
1 Week ago, started rough running.
Rough idle and poor running at normal acceleration.
Had codes checked and got
Lean bank 1
MAF
Random misfires
Replaced the MAF and checked codes again
MAF gone, but random misfire and misfire on cyl 3
Replaced Plugs
Replaced Wires
Replaced Coil Pack on cylinder 3
Pulled negative wire and left off for entire process. (??Does this clear codes??) I don't own the code reader the local autozone does. Is there a safety mode that the car runs in until a code is cleared and removing a cable doesnt fix.
Smelled gas from exhaust more pronounced than usual.
Unplugged O2 sensors and started car. Exhaust smelled better idled better.
Ran without 02 plugged in. Same running issues.
Where should I venture next. Possibly a fuel injector?
Maybe just to the mechanic would be the logical step instead of throwing money at possible ideas.
Mat
6 cyl
Lean bank 1
MAF
Random misfires
Replaced Plugs
Replaced Wires
Mat
Both or 1 at a time and if so which one.
Why wouldn't it throw a code for an 02 sensor and still continue the code for misfire on 3 or random misfire.
Mat
Mat
Welcome to the "Randome Misfire" Club. My 97 (with engine #2) is doing the same thing, but I'm constantly getting a Misfire in Cyl. #2. I've done everything you did and still no change.
Let me know how the new O2 sensor works.
Bob
Bob
I would replace the front O2 just because it's due anyways (don't worry about the rear, it doesn't affect the running condition, just monitors the efficiency of the cat) and test the injectors.
zytra
Jan 24, 2019 03:16 PM
