Last edit by: IB Advertising
- Toyota 4Runner 1996-2002: 4WD General Information
Important information to help you understand your 4Runner.
1996 4Runner AWD?
1996 4Runner AWD?
Hi, I'm shopping for a third gen 4Runner and just looked at a really clean '96 SR5 model. One thing that surprised me was that it is an AWD, not the usual 2wd / 4wd I was expecting. I've been Googling and can't seem to find any information on this particular model, it's like they don't exist. Does anyone have any info on the AWD version of the gen 3?
From: Shelburne, VT previous: Everett, WA; Bellingham, WA
closest thing to AWD were the later models (multimode transmission/center diff. lock, etc) if i have it right. i think they started in 99-00 limiteds, and expanded in 01-02.
the 4runner you looked at (assuming it's a 96) is either:
a) 4 wheel drive (two sticks), or
b) 2 wheel drive (one stick)
I don't think a awd version of the 4x4 4runner happened untill the 99 model year. They are not just plain awd they have an option to run 2wd-awd-4hi-4lo. Just look under the rig and see if it has a transfercase,front diff and cv's...should be pretty easy to identify. Now that I think about it you dont even need to look under the rig.... You should see a 4wd lever next to the shifter auto or manual and know if its 2wd or not.
ahh you beat me to it Nuthuts
'96s came in 2wd and 4wd - that's it. Although, someone could have retro-fitted a 99+ t-case in there so it's possible that it could be multi-mode. If the guy is claiming that it has AWD only (no 4wd), they don't exist.
It's not the Limited model, it's SR5. And there's no transfer case shift stick, only the transmission stick. I'll have to go back for a second look in the daylight (was dark by the time I took it for a test drive) to look underneath and confirm what's going on. I hope he's not lying to me, it's really hard finding the 3rd generation trucks for sale at a reasonable price around here.
AWD didn't actually start until 2001, then they offered an unlockable center (aka tcase) differential. In the 99-00 limiteds, you had 2HI, then you could push a button for 4WD. Since the center diff didn't unlock, you were in actual 4WD. Pushing the lever forward gained you 4LO.
2001+ they offered a stick with 2HI, 4HI, 4HI-L (locked case) N, and 4LO-L. They changed the shift pattern from a H-N-L (96-00 limited) to a J shift pattern with a push button 4WD button.
It will be REALLY easy to figure this out. There will either be one stick, or two. That simple.
If the truck is a V6 and a manual trans, it can ONLY be a 4x4. 4Runners did not offer a 2WD V6 5speed in 1996. It is possible that its a 4cyl 2WD 5speed, but its SUPER SUPER rare, and not SR5 IIRC.
However as stated above by other members, it simply cannot be an AWD because they didn't offer it that year. It can only be 2WD, or 4WD.
Flying91
45
Apr 11, 2024 04:39 PM
Jun 1, 2021 01:51 PM
BeMiceElf
Oct 10, 2015 09:40 PM
cgilley
Jul 15, 2015 03:32 AM
