Stock 99 2.7L Xtr Cab Build
I have a stock 99 Tacoma 4x4 and after ten years and 140k miles have decided to upgrade. I am replacing my stock suspension with a Northwest Offroad 3in Suspension Lift ( Springs and Coil Over not blocks). Does anyone have any experience with Northwest Offroad? And with a 3in lift, what clearance for tires do I have? I admit I am a rookie and am looking for any advice since this is just my first step with a Tacoma that I am pretty attached to.
Hey Guys, I appreciate the info. I got a hold of the search function and found some good hits on the Toytec 3in lift with a rear spring replacement. I am going to do a little more research to make sure I have the right answer. I am also going to start a post in the build up section and put my progress in there. Again, thanks for the steer.
I bought mine from Toytec too. I'm happy as hell with my lift and the ride quality. Check out sonoransteel.com also. Both are very good.
As far as clearance for tires, 33s w/ a 3" lift, but we need to know your rim size to tell you your options.
Allright guys, I made the plunge and bought the Toytect OME 3in lift with a full spring leaf replacement, 1in diff drop and steering bushings. I have started a build up thread under Bamfords 1999 Zombie Truck Build. I hope you take a look and any advice or suggestions are welcome. I will post pics ASAP.
Flying91
45
Apr 11, 2024 04:39 PM
Jun 1, 2021 01:51 PM
