speedo not working and ABS light on suddenly
Old Jan 20, 2010 | 02:58 PM
cpizzle42's Avatar
Exclamation speedo not working and ABS light on suddenly
My ABS light is on and speedo have suddenly stopped working. This is after two night ago when I hard wired a CB to my bat.
Things I have checked so far...
ABS sensors on the hubs(just visually to see if they are plugged in)
brake fluid
ABS fuse under hood
Plug on side of tranny for speedo
Any ideas???
Old Jan 20, 2010 | 05:13 PM
cpizzle42's Avatar
Now I am getting a CEL with a OB2 code of P0500 http://www.obd-codes.com/p0500
What the heck??
Old Jan 20, 2010 | 08:10 PM
RobD's Avatar
Any chance you slice or pulled apart the wire for your speed sensor while looking for a power lead for your CB?
Old Jan 20, 2010 | 09:55 PM
cpizzle42's Avatar
I figured it out while trying to explain it to my girlfriend (haha) I am using a add-a-fuse f tapped into the 12v fuse block under the dash for "switched" power to light a gauge. I tapped the ECU fuse spot instead of the cig light spot.
I just drove it and everything is back to how it should be. Yeah I am dumb....
Jun 1, 2021 01:51 PM
colinmil
Jul 6, 2015 04:03 PM
HRDC0R19
Jul 5, 2015 06:43 PM
cchinny
Jun 25, 2015 08:11 PM
gog1968
Jun 22, 2015 05:55 AM
