Annoying lights on chime
Old Jan 19, 2010 | 09:42 PM
BMWToyotaMan's Avatar
I guess the wiring is getting old on my 4runner or something is broken but I gotta fix this annoying chime! Everytime I open the door the car makes the lights on warning chime until the door is shut.
Is the actual light switch stick bad or is there somewhere else I should look? Has this happened to anyone else?
Thanks,
Jeff
Old Jan 22, 2010 | 10:22 AM
Anyone have any ideas on this? It would be nice to not hear the chime blaring every time I open the door. I dont want to just disable the chime as it is nice to know if you have left your lights on when you get out of your car. Anyone know where I can see a wiring diagram on the chime box and what wires lead into it?
Jeff
Old Jan 22, 2010 | 05:25 PM
TheDurk's Avatar
My '99 doesn't have a light chime; the car just turns off the lights if you exit the car with the key off. My guess is all '99+ are like that, so most of us have no way to help you. And all the on-line wire diagrams I have bookmarked are '99+, too. You need a '98 Wiring Manual. Sorry.
Old Jan 23, 2010 | 02:06 PM
If I can find a wiring diagram I bet I can see if its the lights that are causing it or the key in ignition side thats causing the chime.
I'll look around.
Old Mar 3, 2010 | 05:09 PM
I went ahead and dismatled the annoying buzzer at the bottom of the fuse box. I feel better now.
AkitaDog
Sep 1, 2015 08:05 AM
PopsDad1
Jul 30, 2015 02:21 PM
vanion2
Jul 29, 2015 06:17 PM
4Runnin2000
Jul 29, 2015 06:09 PM
