Injector Swap
Old Jan 20, 2010 | 10:38 AM
Bobs4Runner's Avatar
Injector Swap
Need to swap injectors to see if the problem I am having with a misfire is related.
My question is: what do I need to do the swap? I talked to toyota today and I asked for the o-rings, but then they ask about the 2 other gromets...do I need those also?
Also IF (and i'm hoping) that the issue is the injector, where/what make should I order one? The dealer quoted me a price of $180/injector.
Thanks
Bob
Old Jan 20, 2010 | 10:41 AM
strykersd's Avatar
If you can afford the down time send your injectors out to get cleaned, balanced and flow tested. I sent mine to Witch Hunter Performance ( http://www.witchhunter.com/ ), they charge $18 per injector
Old Jan 28, 2010 | 03:45 PM
Yota Yeti's Avatar
I did all of this and still ended up replacing the injector from Autozone, about $130. All i replaced were the O-rings, and manifold gaskets. (1 upper and 1 Lower)
Doug4320
Mar 24, 2018 10:11 PM
RatOmeter
Oct 22, 2015 03:17 PM
steve miller
Oct 10, 2015 01:40 AM
pyramid
Jul 29, 2015 06:53 AM
GeoRoss
Jul 24, 2015 03:03 PM
