Locks not working........
So, I replaced my tailgate on my 2000 4runner limited 4x4 and now the keyless isn't working. The power locks only work when the key is in the on position. I completely moved the wiring harness to the new tailgate and moved the relay (orange box) to the new tailgate. Any ideas as to what the problem is???
That's what i originally thought but the power window works and the locks work in the on position. None of the locks work with out the key in the on position. Whether or not the tailgate is even hooked up.
If you want to try what team_gforce said:
http://www.4runners.org/writeups/rs3000/index.html
It is probably the fues in the engine bay.
I had the same problem, key on, locks worked, key off, not pwr locks there, no rear window, checked fuses under the hood. replaced on, now locks work.
now if I could just figure out what is preventing the rear tailgate switch to operate the window, or pwr lock, and dome light? Does that orange box control things like the power window in the door when using the key from the back.
That orange box is the receiver for keyless, Controls the rear light. and the window. It does pretty much everything for the rear end.
PNW94Runner
Sep 29, 2015 02:55 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
Sep 24, 2015 03:30 PM
zz_denis
Sep 6, 2015 03:43 PM
