98' Tacoma won't shift
Old Jan 20, 2010 | 08:38 AM
53-echo's Avatar
My 98 five speed, 4cyl, started having some trouble last night on the way home. I couldn't get it to shift into anything using the clutch. There is plenty of fluid, and the pedal is never getting stuck. I thought that since it was 25 below something froze up, but after all night in the garage I can't get it into reverse ( without shuttting it off). But even doing that is starting to go south because the clutch won't disengage anything. The truck has 125 K on it and hasn't had any other problems.
Any advice on where or what I should start looking at?
Old Jan 20, 2010 | 01:22 PM
53-echo's Avatar
So after some reading it sounds like it's either the slave or master cylinder. I haven't bleed the system yet, and think that should be on the top of my list. Am I on the right track?
Old Jan 20, 2010 | 01:27 PM
vital22re's Avatar
totally a bro
try bleeding it and have some one watching to make sure the fork moves its full cycle. Did it slip at all?
Old Jan 20, 2010 | 01:34 PM
53-echo's Avatar
I'll bleed it first thing this evening. I never felt anything slip, it just started getting a little tough to shift in especially when the RPM's weren't matched, then it got really bad. When the clutch is all the way down it still tries to creep forward, and impossible to get first without turning it off and starting in gear.
Thanks
Old Jan 20, 2010 | 01:38 PM
vital22re's Avatar
totally a bro
sounds more like hyrolic then. pull the boot off of the slave cylinder and look inside for moisture or rust.. if present replace. Clutch fluid is nothing more than dot 3 brake fluid. a full flush would be nice considering most people never replace it.
Old Jan 20, 2010 | 01:49 PM
53-echo's Avatar
Do I need a pressure system to flush the fluid? My tools are just as limited as my knowledge.
Old Jan 20, 2010 | 01:53 PM
Gerdo's Avatar
My 4runner did that. It started to just creep a little. As I drove to the shop it wouldn't stop. It was the clutch master cylinder.
Old Jan 20, 2010 | 01:57 PM
53-echo's Avatar
Just to make sure. Is it good practice to swap out both the Master and Slave cylinders is bad? I've heard that if the slave is shot that could mean you had some garbage get into the master cylinder too.
Old Jan 20, 2010 | 02:15 PM
vital22re's Avatar
totally a bro
its possible... living in alaska, you're dealing with extream temps and probly a lot of moisture in the system.. Could be a good idea to do both. As far as flushing it. remove the slave and disconect the master. Blow that line out with compressed air.
Old Jan 20, 2010 | 02:24 PM
53-echo's Avatar
Awesome, thanks for all the tips and I'll update what I find out.
smthwsn357
May 1, 2024 07:28 AM
BeMiceElf
Oct 10, 2015 09:40 PM
Tykiller1994
Aug 10, 2015 07:49 PM
jgwerth
Jul 16, 2015 03:23 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
