bad cat?
Old Jun 16, 2004 | 09:53 PM
SolidDigital's Avatar
bad cat?
my truck's been making this ticking sound from somewhere around the 02 sensor and the cat... I've had a mechanic listen to it and had it checked out at midas, both of them said they couldn't find a leak... so I'm starting to think it's my cat making the noise.?
I'm thinking of ordering a carsound cat or a dynomax, I've searched on here but can't find a site to order it from... does one of these sound good? and if you know of a site that sells them please let me know, thanks guys
Old Jun 17, 2004 | 01:03 AM
Bigkahuna808's Avatar
When I took out my cat and put a cherry bomb in. My bomb would tick and crackle like crazy even a hour after I turned off my engine. It was all the raw fuel combusting itself in the cherry bomb. When I put a high flow cat back on, it stoped
Old Jun 17, 2004 | 01:33 PM
I'm thinking since this looks like the origonal cat with 183k on it, its probably pretty much done in for anyway.. looked at summitracing.com and they have a 2.25" one from catco for $55.
prolly end up giving one of those a shot, but it would be nice if some of you with aftermarket cats could chime in and lemme know what type you put on.
as long as round fits up in there I'd rather get that than an oval one,.
Old Jun 17, 2004 | 08:47 PM
maybe I should just delete this thread and try again haha
Old Jun 18, 2004 | 02:50 AM
Im using a high flow cat, and I think its dynomax. If Im not mistaken. I like it, no more of that stupid pining/ ticking sound.
Old Jun 18, 2004 | 12:55 PM
when I measured mine, it's amost 18" long. The one I'm looking at is 14", is your cat shorter than the origonal one?
Old Jun 20, 2004 | 07:49 PM
Universal, 14 in. long, 2 in. diameter slip fit inlet and outlet, stainless steel, catalytic converter
just ordered that one from summitracing, it's made by catco. figured I'd stay with 2" in case I ever want to go back to stock exhaust instead of 2.25" catback like i'ma do along with a dynomax muffler.
Old Jun 21, 2004 | 05:12 AM
BajaRunner's Avatar
So what do aftermarket cats do ot your exhaust, sound wise? Im looking to get a little bit of a beefier tone from my exhaust, would this help?
Also, your old cat is definetly busted, it makes that sound when part of the filter breaks off. My 89 4Runner had a bad cat in it, and it made a weird ticking sound when going from high RPMs to low.
Old Jun 21, 2004 | 12:09 PM
I think it probably would give it a bit more of a mighty tone haha.
a few years back when I had stock everything, I cleaned the air box and took the air filter out for a min to see if it made a difference... just that gave the stock exhaust a meaner sound. so I got a k&n.
I'm sure the cat would help, also if you don't have 2.5" pipe on your 3.4, maybe welding that from the exit of the muffler out would help also.
tj884Rdlx
Aug 28, 2015 12:04 PM
cr@ves4wheelin
3.4 Swaps
Aug 17, 2015 07:47 AM
skeeter0288
Aug 16, 2015 09:40 PM
129Creepin
Aug 5, 2015 10:12 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
