Question on Brembo rotors
Old Jun 20, 2004 | 10:04 AM
FunRunner01's Avatar
I did a search and read that everyone has problems with rotors in a 4Runner. Are the Brembo 45 dollar ones from the tire rack any better? I know gadget has talked about slotted rotors on his web site, but has gone back to the disposable OEM rotors.
I have also read the cross-drilled tend to crack.
I had my OEm rotors turned about 3000k ago and they have warped and I want new ones.
Any suggestions? I mainly do street driving.
Old Jun 20, 2004 | 10:26 AM
calamaridog's Avatar
I suggest stock rotors and performance friction pads.
Old Jun 20, 2004 | 10:45 AM
Juggalo's Avatar
I just got brand new Toyota rotors, pads/shoes installed, and so far so good *knocks on wood*
My previous MX-6 had Brembo cross drilled rotors (front and rear) and performance pads, with steel brake lines that I thought were great... Until they warped within about 5,000 miles of driving (so what if I had to use them pretty hard at 130mph+?)
Old Jun 20, 2004 | 11:26 AM
Hatchtec's Avatar
What are the price ranges for 94 SR5 4WD brake rotors???
How come I got a price quote for $175 A PIECE!!! for my 4Runner... Were they smoking crack when they quoted me? I just turned around and left when I got that price.. This was a parts store too!..
Old Jun 20, 2004 | 01:00 PM
Gadget's Avatar
Brembo does not make a cross drilled rotor for the 3rd gen 4Runner. There are some out there but they are not cross drilled by Brembo and Brembo does not like the fact that others drill their rotor and try to pass it off as a Brembo drill job.
Anyway, I seem to go through the OEM Toyota rotors pretty quick and can warp them in short order. I had the same trouble on my F-150 and installed a set of Brembo rotors and they do not seem to be warping. I now have put two sets of pads on the Brembos and they still are not warped.
Hoping to have the same luck with the two 4Runners of mine, I put Brembos on them and so far so good. They are lasting longer then OEM.
I have no idea what is different about them. In fact to me they look identical, but some how they seem to hold up better. Lets hope it stays that way.
Gadget
Old Jun 20, 2004 | 01:31 PM
What about pads?
Also gadget do you know where you can set steel brake lines for a stock 01? You mentioned SMC, but their website is no longer up.
Old Jun 20, 2004 | 02:06 PM
Juggalo's Avatar
www.tirerack.com sells Brembo rotors, ceramic pads, and steel brake lines for most applications. I think their prices are pretty fair too.
Old Jun 20, 2004 | 02:52 PM
Bigkahuna808's Avatar
Im running brembo right now. My rotors havent warped to the best of my knowadge. I am looking to replace them though. Im looking into powerslot rotors. With performance friciton pads.
88sasturbotoy
Jan 30, 2026 01:57 PM
garagespace
Oct 11, 2015 10:59 AM
makemusic116
Aug 2, 2015 04:40 AM
ahriman
Aug 1, 2015 10:38 AM
msane99
Jul 11, 2015 08:08 PM
