clutch bushing
Old Jun 17, 2004 | 04:38 PM
SolidDigital's Avatar
clutch bushing
I had my clutch replaced last summer and it's done this since a few months after: it'll squeak when I press it in, but only when it's a certain temp. and humidity outside. I'm thinking they must have forgotten to grease the clutch pedal bushing.
is there anyway to grease it without taking everything apart? :pat:
Old Jun 17, 2004 | 09:30 PM
Adam F's Avatar
Clutch pedal bushing? I don't remember seeing one when i replaced the clutch master cylinder and stuff. Maybe I'm stupid? Or maybe there is something binding up or needs to be adjusted? I thought it was just a metal rod that connects to a large nut and then to the back of the pedal.
Old Jun 17, 2004 | 10:14 PM
maybe that's not what it is... it's just weird how sometimes it makes that squeaking sound and other times it doesn't.
earlier today it was doing it really bad, and tonight when I went to get gas I could hardly tell there was a problem.
it never did it before with the old clutch though, the worst part is the place that replaced it went out of business so I can't take it back and get them to fix whatever it was they did wrong
Old Jun 17, 2004 | 10:42 PM
Bob_98SR5's Avatar
might be your clutch master cylinder. thats what's causing mine.
bob
Old Jun 18, 2004 | 07:36 PM
if it's that, would it squeak even with the engine off?
the mechanic that replaced the clutch, also did the timing belt. he forgot to tighten the timing belt tensioner or something and had to go back in there to fix it.
Old Jun 18, 2004 | 07:52 PM
TechWrench's Avatar
Check the contact points between the clutch slave cylinder and the clutch fork. And the point the clutch fork pivots on the housing. One of them might be the source of the squeak. A little moly lube on each point should fix it if it is.
mwisham
May 26, 2021 02:51 PM
aowRS
Sep 13, 2017 08:22 AM
briholt
Sep 20, 2015 10:26 PM
JRB4Runner2015
Sep 20, 2015 12:29 AM
Pocoyota
Sep 8, 2015 02:41 PM
