cap and rotor for 3.0 question
Old Jun 22, 2004 | 06:59 PM
SolidDigital's Avatar
well I have a brand new set of wires now because I broke one pulling it off, but I'm not going to install them till I get a cap and rotor tomorrow.
the pack of wires came with some dielectric grease, and I was just thinking.. should I put some on the rotor and the contact points on the cap to maybe keep it from rusting out like my current ones did??
is this a bad idea?
Old Jun 22, 2004 | 07:53 PM
gwhayduke's Avatar
Yep...Bad idea. The inside of your distributor moves...and moves fast. You don't want the grease getting slung around in there and grounding out your spark.
Old Jun 22, 2004 | 08:00 PM
86toyota's Avatar
Dielectric grease is Non -conductive. It's main purpose is for corrision and heat dissipation. That said , I still wouldn't put in in the cap either.
Old Jun 22, 2004 | 10:07 PM
AgRunner06's Avatar
I second their opinions. Don't do it. Just use it on the plugs and the top of the dist. cap.
Old Jun 22, 2004 | 11:11 PM
thanks guys, I just checked in the haynes manual and it does say to put a dab of silicone lubricant on each terminal in the cap. the only type I have is in a spray can though... should I put a little bit of that on each one or forget that idea also?
Old Jun 23, 2004 | 04:24 AM
gwhayduke's Avatar
Learn something new everyday...
As for lubing the distributor cap with silicon. I've never done it and most likely never will. The silicon lube will impede the flow of electrictiy. I always made sure everything was clean and dry, just like the hermetically sealed mayonaise jar on Funk & Wagnall's front porch.
sandyota
Feb 4, 2021 11:16 AM
Sleaker
Aug 26, 2020 06:03 AM
msane99
Jul 11, 2015 08:08 PM
smiley52
Jul 11, 2015 05:16 AM
Coreyr384
Jul 10, 2015 11:13 AM
