Going in for service tomorrow, please help.
Old Jun 16, 2004 | 06:54 PM
anthraciterunner's Avatar
Tomorrow, I am going to toyota for a minor service and I got my Bilsteins shipped to me today. I will ask them how muck to install. Can you guys give me a ball park as to how much I should expect to pay? Also, just so they don't try to rip me off too much...how much time for labor does the install usually take? This is on a 3rd gen, 4wd.-thanks
Old Jun 16, 2004 | 06:56 PM
My99's Avatar
If you lived nearby and I was doing freelance work for you, i'd probably charge about 75-100 bucks for shocks. Since you're a yota guy, i'd help you for free tho. No one else around you interested in lending a hand?
Old Jun 16, 2004 | 08:19 PM
Mad Chemist's Avatar
Joe, if you have the time, try it yourself. Its not that hard, rear shock top nuts are a royal biatch, but not impossible...
Old Jun 16, 2004 | 08:55 PM
2wd1stgen's Avatar
"rear shock top nuts are a royal biatch" mad chemist please explain in more detail. Is it hard to get to, usaully rusted on, or just a biatch? I plan on swapping out all my shocks very soon.
Old Jun 16, 2004 | 09:02 PM
I would love to do it myself but I have a very limited amount of tools and this is my only mode of transportation. I would be screwed if I got stuck in the middle of the install. I asked the guy from toyota real quick and he quoted a rough estimate of 160 dollars. Of course it would be free if I could do it myself but I would rather get this done because I got a lot of things going on right now.
Since they charge labor by the hour, I was hoping to get an estimate on install times from you guys so I now what better to expect.-thanks
Old Jun 16, 2004 | 09:25 PM
rimpainter.com's Avatar
Hard to get to? Yes.
Rusted on? Depends on your region.
Took me about 1.5 hours to do my rears. You will get your arms into positions that you never thought possible, trust me.
Old Jun 17, 2004 | 04:52 AM
Marc P's Avatar
I work at a Ford dealership--I am sure labor time to install shocks are the same--we charge 1 hour per axle, so a total of 2 hours at whatever labor rate that dealer is at.
Old Jun 17, 2004 | 05:10 AM
waskillywabbit's Avatar
Talking Diy
You can check out what I had to do for my rear shocks in my write-up here:
CLICKY
Old Jun 17, 2004 | 06:31 AM
Yeah just a bad spot, not necessarily rusty. What worked for me was putting the ratchet on the top nut, then a 12 inch breaker on the ratchet. With a strap wrench on the shockbody I twisted the shock, which spins the whole thing, including the top schock nut until the breakerbar was levered against part of the frame/body. At this point it was just a matter of continuing to use the strap wrench to get the shock off. I had soaked the nut for ~3 days in PB blaster, a spray in the morning and one at night, and that seemed to help a bit.
Old Jun 17, 2004 | 06:35 AM
TRunner's Avatar
Not the same model, but for any car it would not take me more then an hour or two by myslef to change the shocks. That is easier then changing oil in most cases.
Old Jun 17, 2004 | 09:18 AM
If you have not had the shocks put on yet you should try a different shop to do the work. An independent shop will not charge as much on the hour as the dealer. This is just a thought later.
JookUpVandetti
Sep 17, 2015 09:25 PM
Tacoma1313
Sep 15, 2015 07:51 AM
mdh
Sep 15, 2015 12:12 AM
LotOMiles
Sep 14, 2015 11:45 PM
jacked_72
Sep 14, 2015 03:31 PM
