3rd Gen idles a little rough
Old Jun 16, 2004 | 10:22 AM
DrummerDaveB's Avatar
It seems to very slowly getting worse.
At idle it is rough, but not so much like a stumble, but more like a cycling vibration that is on a 2 second interval. A/C is not on so I know it isnt my compressor cycling..
You guys have any ideas as to what might be the cause?
Old Jun 16, 2004 | 10:30 AM
DavidA's Avatar
Dirty Fuel Filter?
Fouled Plugs?
Old Jun 16, 2004 | 11:29 AM
rimpainter.com's Avatar
Fouled plugs, faulty coil pack, faulty wires. That would be my first guesses.
Old Jun 17, 2004 | 06:17 AM
Ok, so here's what I'll try.
1) Plug Wires - Original 85k miles
2) Fuel Filter - probably original.
3) Check plugs - replaced about 20k miles ago.
4) Live with it unless it gets really bad. I dont want to replace coil packs unless I have to.
Thanks for the Suggestions!
Old Jun 17, 2004 | 08:08 AM
Test everything before you go replacing it. That will save money and time.
A multi-meter will handle the coil packs/plug wires.
Old Jun 19, 2004 | 03:11 AM
oscarz's Avatar
DrummerDave,
I have an 03 V6 and it does the exact same thing from brand new on. I've noticed it in some other 4runners too, so it's not an isolated quirk. If you figure it out, please post.
Old Jun 21, 2004 | 06:59 AM
fsudave's Avatar
I have a 98 v6 with similar engine vibration symptoms - sort of an on and off cyclical vibration. Sometimes the idle slowly drops to 500 RPM, the vibration increases, then it quickly pops back up to ~650. Nothing extreme, just annoying. Replaced fuel filter, plugs and wires, cleaned TB, ran several cans of fuel injection cleaner. No change - still the same. I wonder if it is supposed to be like this?
Old Jun 21, 2004 | 07:09 AM
No, it's not.
Old Jun 21, 2004 | 07:13 AM
bamachem's Avatar
No, it's not supposed to run that way...
Have you seen this? Good reading material that might help...
https://www.yotatech.com/forums/showthread.php?t=35112
Old Jun 21, 2004 | 08:36 AM
Thanks Bamachem! I'll have to try that first.
So maybe the cycling we feel is caused by slightly higher compression in some cylinders, or maybe clogged injectors in some cylinders?
Where can I buy some Seafoam? Does Autozone carry it?
Old Jun 21, 2004 | 09:16 AM
bamachem's Avatar
I got mine from napa. look for a metal can, maybe 7 or so inches tall with red and white graphics.
Old Jun 21, 2004 | 10:42 AM
Thanks again Bamachem!
I'll definitely try this stuff.
Old Jun 22, 2004 | 05:43 PM
oscarz's Avatar
DrummerDave,
My rpms do not change during the vibration. How bout yours?
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
montanatruck
Feb 26, 2017 07:07 AM
tomczaksdiesel
Jul 26, 2015 10:35 PM
