3rd Gen idles a little rough
It seems to very slowly getting worse.
At idle it is rough, but not so much like a stumble, but more like a cycling vibration that is on a 2 second interval. A/C is not on so I know it isnt my compressor cycling..
You guys have any ideas as to what might be the cause?
Fouled Plugs?
Ok, so here's what I'll try.
1) Plug Wires - Original 85k miles
2) Fuel Filter - probably original.
3) Check plugs - replaced about 20k miles ago.
4) Live with it unless it gets really bad. I dont want to replace coil packs unless I have to.
Thanks for the Suggestions!
I have a 98 v6 with similar engine vibration symptoms - sort of an on and off cyclical vibration. Sometimes the idle slowly drops to 500 RPM, the vibration increases, then it quickly pops back up to ~650. Nothing extreme, just annoying. Replaced fuel filter, plugs and wires, cleaned TB, ran several cans of fuel injection cleaner. No change - still the same. I wonder if it is supposed to be like this?
No, it's not supposed to run that way...
Have you seen this? Good reading material that might help...
https://www.yotatech.com/forums/showthread.php?t=35112
So maybe the cycling we feel is caused by slightly higher compression in some cylinders, or maybe clogged injectors in some cylinders?
Where can I buy some Seafoam? Does Autozone carry it?
montanatruck
Feb 26, 2017 07:07 AM
nframe
3.4 Swaps
Aug 16, 2015 09:03 AM
