Which Wheels????
Old Feb 2, 2008 | 04:24 PM
OSU4Runner's Avatar
Which Wheels????
I'm installing a set of 285/75R16's on my 4runner this month. I was gonna mount them to my stock 16x7 5 spoke limited wheels, but I'm thinking about picking up a set of Cragar soft blacks. I know I need a 16" wheel, but should I stick with the 16x7 or would a 16x8 fit these tires better? Also, what backspacing and bolt pattern do I need to get? Here is the link to the wheels. Thanks!
http://store.summitracing.com/egnsea...115+4294793322
Old Feb 7, 2008 | 11:15 PM
mpavolka's Avatar
Don't know a whole lot about what spacing to use, but I am sure you could search and find it. With that big of a tire you definately want to get a 16x8. It will give you a better look, as well as extent tire life since you can put a more even pattern on the ground. My brother bought Crager black steel wheels from Jegs.com. Spent $36 a wheel plus center caps, he hs had them for two years and they still look brand new. Jegs.com also has free shipping!
Old Feb 8, 2008 | 07:48 AM
Nate08's Avatar
Definately 16x8. I've heard the magic number for backspacing is 4.5", however I would prefer one around 3.75" so it pulls away from the UCA more.
Old Feb 8, 2008 | 08:36 AM
Victor's Avatar
16X8 would let you mount a 305/70 which is the same height but wider. What Nate said about the backspace....
Old Feb 10, 2008 | 11:19 AM
HatterasJack's Avatar
I have a 99 Highlander with OME Spirngs and shocks all around which is supposed to give you a 2" lift. I ordered 305/70 R16's on 16x8 wheels with BFG M/Ts. I had to send them back because they rubbed big time on the rear of the front fender wells. I have been struggling with finding the right combination of wheels and tires for this truck. I like the look of wider tires and enjoy the greater floatation on the sand. I ahve seen alot of 285/75 R16's on the stock wheels but most tire guys tell me that they will not fit.
I can tell you for sure that the 305/70's will not fit without some significant lifting. I was looking for confirmation from someone that the 285/75's will fit and what tires you guys recommend. I had great luck with Kumho M/Ts on my old 4Runner ('94 V6) until I flipped it off a bridge into a creek. You cannot get those tires anymore those.
Size and brand/model input welcome.
Old Feb 10, 2008 | 11:29 AM
turboale's Avatar
Time for a body lift...
Old Feb 11, 2008 | 08:26 AM
OSU4Runner's Avatar
Alright....I went with some black pro comp extreme rock crawler steelies, series 97...16x8 with 4" of backspacing. I just test fit them, they are about a 1/4" away from the calipers, but no rubbing so I guess I'm good. I might do a bit of grinding just to be safe.
kouki420
Sep 2, 2015 11:42 AM
NCRidgeRunner
Aug 13, 2015 04:11 AM
Up&Down
Aug 5, 2015 06:20 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
skoti89
Jul 6, 2015 07:45 PM
