Bleeding brakes and MC question
Old Jan 22, 2008 | 09:56 AM
mkgarrison5's Avatar
hey guys so i changed my front pads and the brakes still arent that great. After further thought i really think it maybe the brake fluid also. it hasnt been changed since i bought it over 50k miles ago (2.5 years or less).. in order for me to atleast try and mark this off my list i have a few questions..
1. how do you get the brake fluid out of the master cylinder? i was told you can siphon it out and replace the fluid. I am assuming thats the brake fluid resevoir? or not?
2. silly question but i am new to brakes.. how do you properly bleed the brakes on an 02 tacoma? front and back. I have read in many places that brake fluid really doesnt circulate therefore the brake fluid that is in my lines may very well be over 60k miles old or older..
please correct me if i am wrong on this stuff and some tips would be great! thanks fellas
Old Jan 22, 2008 | 10:01 AM
vegaskurt's Avatar
You would start at the passenger rear, then drivers rear, then passenger front then drivers front for bleeding. If you got $50 to spend get a motive pressure bleeder and you can do it by yourself in 10 minutes.
Other wise just get a buddy to pump the brakes as you bleed and top of the master cylinder after each tire. Keep opening/closing the bleeder valve on each wheel till you see nice new clean fluid comes out.
Old Jan 22, 2008 | 10:05 AM
second silly question.. exactly where are the bleeders located? i never have messed with brakes. i can do waterpumps, etc etc but brakes--- no idea lol.. thanks for bearing with me here guys
Old Jan 22, 2008 | 10:06 AM
also do you do this with the truck on or off?
Old Jan 22, 2008 | 03:44 PM
Ultraman V's Avatar
The truck does not have to be running to do the brakes.
Also, one thing to warn against.....be very carefull with an open ended box wrench on the bleeder nipples, they can strip very easily. It's best to get a brake line wrench, it's like a cross between an open ended wrench and a closed one.
One other thing, do a few google's on brake bleeding, there is a lot of good step-by step methods available.
Old Jan 22, 2008 | 05:14 PM
MTL_4runner's Avatar
Turkey baster works great for this.....just make sure to get your wife a new one.
Using a power bleeder with compressed air works best, but the old pedal method can be used if you ensure you don't push the pedal past it's normal travel. Start at the rear and work your way forward on each corner.
Power bleeder:
http://www.ultimateyota.com/index.ph...16142#msg16142
Brake bleeding:
http://www.4x4wire.com/toyota/4Runne...enance/brakes/
Answers in red above.
Old Jan 23, 2008 | 04:30 AM
i have disc brakes in the front and drums in the back. you cant bleed the rear brakes right? atleast it didnt say anything in the 4x4 write up you posted jamie. also what did you mean by not allowing the brake to hit the floor and to keep it in its normal range? i assume you mean for me to close the bleeder before the pedal hits the floor? sorry guys i am learning about brakes. normally i have buddies that do it but they have moved away for jobs and etc so i am stuck all alone lol :-\ ... thanks fellas!
Old Jan 23, 2008 | 07:24 AM
Bighead's Avatar
Yes, you can bleed the rear drums. If you look at the inside of the drum, you will see the bleeder valve probably covered with a black rubber cap.
Try this write-up and see if it makes more sense... Brake Bleeding
Old Jan 23, 2008 | 07:49 AM
gotcha... i doubt ill buy a bleeder since i would on do this once ever few years or when i get the brakes done. thanks guys... any particular brand of brake fluid you guys use?
Old Jan 23, 2008 | 08:38 AM
hross14's Avatar
[SIZE="4"]SERIOUS NEWS FLASH*******[/SIZE]
I saw these bleeder screws at the O'Rieley/Autozone that have a check valve in them. Unscrew them so far out and it acts like a Check valve. you can pump the brakes and air wont get into the system. ALL BY YOURSELF.
I was kinda giggly like a school girl when i saw them because i like to change my B.F. at least yearly. Is that OCD? HAHa--
Just thought i would share--i thought it was exciting
Old Jan 23, 2008 | 08:52 AM
mjwalfredo's Avatar
Awesome, I know my girlfriend will appreciate this announcement
Old Jan 23, 2008 | 10:33 AM
BF as in boyfriend?? hahahaha sorry i had to :-).. thanks man ill check into those. i hope they arent pieces of like most things from that store
Old Jan 23, 2008 | 11:52 AM
hross14's Avatar
I hope not either--i have yet to use them--but if you use yours first--tell us how they work out. It is a great concept though
fountain
Dec 31, 2015 06:08 AM
Whatever123
Sep 30, 2015 12:12 AM
CanRunner
Jul 20, 2015 01:29 PM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
