Can't pick the right shocks...
Old Feb 6, 2008 | 07:45 PM
Oregoneric's Avatar
First post here, probably in the wrong place, sorry. I'm working in Japan and have a 1997 surf/4ruuner with the 3.0 KZ-TE turbo diesel. I am looking to go up two inches, and I've already bought springs. I have a feeling that they are pretty stiff, and I don't really want loose the cushy 'family ride' too much, so I thought that rancho 9000's would be nice since I could adjust them. I called rancho this morning and was told they don't make a strut for a 2inch lift on my rig, so screw rancho.
I'm wondering if any of you folks have a suggestion for a smooth riding shock combo that will work with a 2 inch bigger spring? I do a fair amount of wheeling as I hunt deer for about 5 months of the year here. I also have the e-locker. And T-max 8500 winch on the front with a fairly light bumper setup, somewhere around 200 pounds including the winch. Your advice would surely be appreciated!
Old Feb 6, 2008 | 08:07 PM
wjwerdna's Avatar
if i am correct, in the front you will not want to go much longer without a limiting strap, as you may allow the CV's to extend into death range...
then again, I am still running stock front/rear shocks with 3" lift and they are shot (garbage)
Old Feb 6, 2008 | 08:42 PM
Texas_Ace's Avatar
you could get the rancho and then just get some blocks to give you that extra hight. This is the way that i am thinking of going although anywhere 1 - 2 inches would be fine for me.
Old Feb 7, 2008 | 01:03 AM
Oregoneric's Avatar
I'm pretty well lost on what to do. Do I need spacers on top of the strut inside the coil? Or should I go with some trekmasters, or , maybe EMU? Or would some soft monroes work well with these stiff springs? Or should I put the springs on with the stock shocks and see what breaks and go from there?
I wish I hadn't bought them springs, then I could go with a EMU system...
Old Feb 7, 2008 | 01:49 AM
olharleyman's Avatar
I have a perfect set of shocks for it just ship it to me hear back in the ol U.S. of A and i'll even install them for ya. I want one of them there diesel hilux's. TRY PRO COMP MX6's they may better then the RANCHO and are made for the lift kit's 2and up
Old Feb 7, 2008 | 02:03 AM
KZN185W's Avatar
Rancho has shocks for 2" lift.they even have shocks for 4" suspension lift..maybe they misunderstood your question...may they thought that you were asking for shocks that can GIVE 2" lift.
Old Feb 7, 2008 | 05:13 AM
Belize Off Road Team's Avatar
Olharleyman speaks truth, lol. Pro Comp makes exellent shocks for lifted vehicles and so does Old Man Emu by ARB. Rancho does make shocks for lifted vehicles, but they dont like to deal with Toyotas for some odd reason (american motors supporter).
Old Feb 7, 2008 | 05:22 AM
Yodaforce's Avatar
Pro Comp. Even their stock application shocks have more travel.
Old Feb 7, 2008 | 10:19 AM
skjos's Avatar
OME
N91SC in front
N86C in back
This may get you close to the cushy ride, but typically a lift makes for a stiffer ride.
choppe777
May 16, 2016 08:00 AM
longbed
Sep 16, 2015 10:35 AM
LotOMiles
Sep 14, 2015 11:45 PM
mirabile4runner
Sep 3, 2015 07:15 AM
