Anyone had this happen???
Old Jan 30, 2008 | 08:34 PM
98horunnin's Avatar
Ok, so my 98 4Runner SR5 came with the big brakes and 16" wheels wrapped with 265/70/16's from the dealer. Ever since I have owned my rig the speedometer has read consistently 2-3 mph under my actual speed. I confirmed this with both stupid roadside radar guns set up by the local PD on a busy highway and then with GPS with the cruise set. When I recently up'd my tire size to 285/75/16's the speedo was right on, again confirmed with radar and GPS. You think this was just the result of a tired speedo after 190k or something else?? Its pretty cool though not having to worry about recalibrating the speedo or gears. Does this tell me anything about my gears btw? Have yet to do the simple task of determining my ratio since the codes on the door and the package the truck finally ended up with tell me nothing. What you guys think?
Old Jan 30, 2008 | 08:36 PM
Ringmaster's Avatar
Mine did the same speedo wise. Most automatics came with 4:30 gears.
Old Jan 31, 2008 | 11:19 AM
98runner210's Avatar
Most vehicles off the assembly line are not precise on the speedometer. A 1-3 MPH variance is normal. anything over that should be recalibrated.
Old Jan 31, 2008 | 07:33 PM
98horunnin's Avatar
Just thought it was weird that its right on now. Was expecting it to go farther below the actual speed of travel.
Old Jan 31, 2008 | 07:45 PM
b.miller123's Avatar
consider yourself lucky, as sometimes it can never "line up" right
I would also be curious to see how much it will change when those tires are worn out
Old Jan 31, 2008 | 08:12 PM
son209's Avatar
My 97 sr5 with 285/75/16 bfg and 4.88 gearing reads 2-3 mph slower than I'm actually doing. Thats based off of my garim c580 portable NAV.
83yotastockR
11
Nov 10, 2015 06:54 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
creecher10
Sep 30, 2015 03:27 PM
beltcutter
Sep 30, 2015 06:14 AM
mluz013
Sep 29, 2015 05:53 PM
