02 Sport lights/wiring help
Old Jan 31, 2008 | 03:50 PM
Deceptiwave's Avatar
I am adding some lights to my yakima rack and I need some help wiring the relay. Where is a good place to get 12v to switch the relay on? under the dash is best, so what color, or what to tap into?
thanks alot!
Old Jan 31, 2008 | 03:53 PM
Elton's Avatar
use a fuse tap
Old Jan 31, 2008 | 04:06 PM
not sure what you mean - can you explain please?
thanks
Old Jan 31, 2008 | 04:29 PM
07sbock's Avatar
A fuse tap is somthing you crimp on the wire then jam it into an open spot on the fuse panel, or remove a fuse and use its location.
Well tap it into the fuse box if you want or go staight to the battery, go to your local parts store pickup a rocker switch, find a good area to mount the switch and wire her up, take some pics too!
Old Jan 31, 2008 | 04:38 PM
cool thanks. does it go in the engine bay or under the dash?
Old Jan 31, 2008 | 04:45 PM
07sbock's Avatar
Well The fuse tap would go in the under the "dash panel". Also you can pick up the fuse tap @ a parts store too.
Big Little Bear
230
Nov 13, 2023 11:42 AM
mskalmus
May 28, 2017 07:51 AM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
ahriman
Aug 1, 2015 10:38 AM
