02 Sport lights/wiring help
I am adding some lights to my yakima rack and I need some help wiring the relay. Where is a good place to get 12v to switch the relay on? under the dash is best, so what color, or what to tap into?
thanks alot! |
use a fuse tap
not sure what you mean - can you explain please?
thanks |
A fuse tap is somthing you crimp on the wire then jam it into an open spot on the fuse panel, or remove a fuse and use its location.
Well tap it into the fuse box if you want or go staight to the battery, go to your local parts store pickup a rocker switch, find a good area to mount the switch and wire her up, take some pics too! |
cool thanks. does it go in the engine bay or under the dash?
Well The fuse tap would go in the under the "dash panel". Also you can pick up the fuse tap @ a parts store too.
