Testing Idle air controll valve
Old Jan 21, 2008 | 05:27 AM
merace19's Avatar
I need to know what the readings for a 2000 tacoma IAC should be? My truck has high idle and i believe that the valve is the problem. I have a reading from the RSC to B+ of 60 ohms, and RSO to B+ of 5 ohms COLD. When I put 12v+ to the B+ and Neg- to the RSC it only twitches the flap a little. But when I but 12v+ to the B+ and the RSO it does nothing. The valve is 229plus tax so I dont want to just replace it it if I dont have to.
Old Jan 21, 2008 | 06:24 AM
pineapple's Avatar
I'm looking at the FSM for a 99 Taco. for the 3RZ-FE the resistance is listed as:
COLD:17.0-24.5 ohms
HOT: 21.5-28.5 ohms
for the5VZ-FE:
COLD:17.0-25.0 ohms
HOT: 21.5-29.5 ohms
Old Jan 21, 2008 | 06:35 AM
pineapple's Avatar
There is a thread listed as 'starting problems' I posted with responses to the IAC that you might check out. Good Luck.
Old Jan 21, 2008 | 07:42 AM
MTL_4runner's Avatar
According to the 00 FSM:
"Using an ohmmeter, measure the resistance between terminal +B and other terminals (RSC, RSO).
Resistance:
Cold 17.0 – 25.0 ohms
Hot 21.5 – 29.5 ohms
If the resistance is not as specified, replace the IAC valve."
So from what you tell me your readings are, you should be replacing it.
smthwsn357
May 1, 2024 07:28 AM
Charecter1
Nov 6, 2023 10:08 AM
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
coryc85
Sep 9, 2015 06:24 AM
