yota pink or yota red coolant
Old 02-04-2008, 08:42 AM
mkgarrison5's Avatar
Liked 0 Times in 0 Posts
hey guys, just talked with my local dealership and mentioned that i wanted pink instead of red (bc they use tap water mix with the red and i dont want tap water) he told me that i cannot use the pink (btw i drive an 02 v6 4x4 taco) bc the system was not designed for it.. is there any truth to this?? he told me red only.
mkgarrison5 is offline
Old 02-04-2008, 09:18 AM
86tuning's Avatar
You can use whatever you want.
The 02 vehicles came out before the super-longlife coolant was introduced in 04.
If you substitute SLLC (pink) in place of LLC (red) don't expect 5 years out of it, you'll have to change it in a couple years anyways due to mixing of the new/old coolant.
Toyota says, 5 years for initial, then 2 year intervals afterwards.
Me, I'd use regular red LLC (red) and filtered or distilled water and be done with it. LLC chemistry isn't as aggressive as SLLC and therefore is nicer to your skin, etc.
Generally, tap water is a no-no, but filtered water is fine.
86tuning is offline
Old 02-04-2008, 09:19 AM
jjrgr21's Avatar
the only difference between the pink and red, the pink is already cut to 50/50 and cost's the same. around $22 a gallon.
my 03 takes pink/red and my 98 took el-cheapo green.
jjrgr21 is offline
Old 02-04-2008, 09:31 AM
dirtoyboy's Avatar
I have never heard of PINK coolant...just red, green and orange
dirtoyboy is offline
Old 02-04-2008, 09:49 AM
wrong the pink is the extended life version and is mixed 50/50 and yes it is different than red in more ways than one. but is it harmful to my taco??
also my local dealerships (all 3 of them) use tap water and have been since they have been open (15+ years) and they swear that tap water is ok with yota red coolant as long as you flush / change every 30kmiles..
i am having them change my tbelt, waterpump and thermstat changed thats why i asked them.
Old 02-04-2008, 09:54 AM
fast7mtoys's Avatar
never had a problem with tap water, NEVER!
fast7mtoys is offline
Old 02-04-2008, 09:58 AM
CJM
CJM's Avatar
Like I said in another post, my shop uses tap water and no issues.
CJM is offline
Old 02-04-2008, 10:04 AM
dirtoyboy's Avatar
yup. you're right......learn me sumfin new everyday...
what I was reading says the pink is "aluminum engine" friendly and is silicate free....is it really good for 100k?
Old 02-04-2008, 10:08 AM
no probably not. i would half that to be honest. nothing really goes as far as they say it goes OEM wise imo.. it really depends on how you drive your vehicle. the rougher you are (city, 4x4, ect ect) the more often you should change fluids, grease and oil.
Old 02-04-2008, 10:09 AM
MTL_4runner's Avatar
Nope, he's full of it. Running pink instead of red will not damage your engine in any way.
The two coolants are very similar except that the pink has added OAT technology.
Ask him why, I'd be curious what sort of reasoning he comes up with besides "that's what called out in the computer".
MTL_4runner is offline
Old 02-04-2008, 10:12 AM
Originally Posted by MTL_4runner View Post
Nope, he's full of it. Running pink instead of red will not damage your engine.
i agree with you and i did ask. he said that the pink is harsher for the pre 2004 vehicles and that when toyota switched to pink they changed a few things in the coolant system in order to use the pink... my side question is would the OAT be the "issue" that he talks about??
Old 02-04-2008, 03:13 PM
OAT = Organic Acid Technology
Yes, I'm sure that's what he was talking about and that is what gives the coolant it's "super long life".
Here's some good reading on the subject of coolants:
http://www.ultimateyota.com/index.ph...26&topic=328.0
What exactly is he claiming they "switched out"?
Old 02-04-2008, 03:31 PM
surf4runner's Avatar
... pink is the extended life version ... but is it harmful to my taco??
pink is the right color for tacos
surf4runner is offline
Old 02-04-2008, 10:45 PM
stormin94's Avatar
I'd go for yota-PRESTONE in the yellow jug.
stormin94 is offline
Old 02-05-2008, 01:04 AM
Demon's Avatar
wow!!! i had no idea tap water was bad...do this mean only on new cars or any in general??? cus i bought the green presto or whatever u call it, and i mixt it with tap water...
Demon is offline
Old 02-05-2008, 01:08 AM
Justinvd's Avatar
We use tap water also at our shop
Justinvd is offline
Old 02-05-2008, 04:52 AM
well i am not going to take my chances with tap water. i will buy 2-4 gallons of distilled water and have them mix that water with the yota red. i am going to have them write it down on the service sheet to make sure they do that and stress it. they seem pretty reasonable as far as what i want done to it and how i want it done so ill cross my fingers..
-- btw i do have prestone "any make, any color" in there now. it has only been in there about 20k miles or so. time to get rid of it.
Old 02-05-2008, 06:23 AM
Seems like alot of trouble for nothing.
I'd just fill it with the long-life pink and forget about it.
Old 02-05-2008, 06:26 AM
i called the guy again and he changed his mind and said this "i guess it would be ok to use the pink BUT we have to make sure all of the red is out of your truck first"... i mean come on man.
i am going with the pink and just tell them to drain what they can out of the coolant system. this is rediculus.. i would rather have the pink anyway and change it every 3-4 years
Old 02-05-2008, 06:28 AM
dirtoyboy's Avatar
tap water is fine for the most part...just do NOT used softened water
Quick Reply: yota pink or yota red coolant
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
