Hella Micro DE Fogs...2 models...
Old Jan 23, 2008 | 09:54 AM
pfdaxe's Avatar
Can anyone tell me what the differance might be between the 2 models of the Hella Micro DE fogs? Besides price, is one a newer "improved" model? Hellas website only list one model....and it's the cheaper priced one. The lens looks clearer on the 2nd one listed below.
http://www.amazon.com/Hella-HLA-H130.../dp/B00042K39C
http://www.amazon.com/Hella-Micro-Ha...m_auto_title_1
Old Jan 23, 2008 | 10:13 AM
skjos's Avatar
I can't tell you the difference, but this link might save you some cash:
http://www.yellowandbluelighting.com...a/Default.aspx
$154 for both fogs, plus all the mounting hardware if you need it.
Old Jan 23, 2008 | 10:42 AM
pfdaxe's Avatar
Hmmmm...not sure if that would be saving any cash since Amazon is cheaper. Those in your link "are" vehicle specific since it comes with the mounts, but I just need the housings since I'm adding an HID system to it. So...the rest of the kit would be a waste for me. But thanks for the link!!
Old Jan 23, 2008 | 03:37 PM
2000t4rAKS's Avatar
pfdaxe,
I am not sure what the difference is between the two models. I think the first one is more a universal and the second one is model specific for our 4Runners. I also have a 2000 4Runner but since mine is a limited, it comes with factory fog lamps from the factory and was interested in replacing the stock fog assembly with this model: HL74560 (This model is model specific and since I have the stock wiring, it would probably be just plug and play). However, I really never got an answer to that question. The second link from amazon is the same company as this:
http://www.rallylights.com/hella/OE_Toyota.htm
And the model number is HL74560. Hope this helps.
-austin
Old Jan 23, 2008 | 03:55 PM
pfdaxe's Avatar
Originally Posted by 2000t4rAKS
pfdaxe,
-austin
Both the ones on Amazon are universal which I would need. I'm just replacing the OEM ones so I can do an HID mod. You can't fit an HID bulb in the OEM fogs. The 4Runner specific one would be good if I didn't have any installed and the higher price is for the mounting hardware that I wouldn't need. Thanks for the link!
Old Jan 23, 2008 | 06:36 PM
skjos's Avatar
Whoops, I didn't read that the amazon price was for two lights. I thought it was just for one. Sorry...
Old Jan 23, 2008 | 07:35 PM
Fo_SheeZy's Avatar
Are you serious you can't fit HID's in the OEM ones?? Man that sucks, I just ordered a set of HID's for them... but is there anyone to buy that Hella Micro DE w/out that HID's because I'm not trying to pay $700...
Old Jan 24, 2008 | 03:16 AM
pfdaxe's Avatar
The OEM are not long enough to fit an HID bulb. The housing is too short. The HID model of the Micro is around $500. I'm buying the halogen model as described in the above links and adding an HID system. Works out cheaper.
Old Jan 24, 2008 | 11:27 AM
Fo_SheeZy's Avatar
So if I buy these right here, the HID will fit in them?
Old Jan 24, 2008 | 11:56 AM
pfdaxe's Avatar
Yep. Or buy these: http://www.amazon.com/Hella-HLA-H130.../dp/B00042K39C
You will probably have to remove the bulb holders but these are longer and can fit an HID H3 bulb.
Old Jan 24, 2008 | 12:26 PM
Fo_SheeZy's Avatar
Which ones are you going to get? I like these better, the lens looks a lot clearer. http://www.amazon.com/Hella-Micro-Ha...m_auto_title_1
Old Jan 24, 2008 | 12:31 PM
pfdaxe's Avatar
I'm not sure yet. It looks shorter but the dementions listed are almost the same. I think one maybe a newer model...
Old Jan 24, 2008 | 12:53 PM
Fo_SheeZy's Avatar
I think I'll order that one tonight, but if it doesn't fit I can always send it back.
Old Jan 24, 2008 | 01:00 PM
pfdaxe's Avatar
I'm sure I'll be ordering in the next few days. Not sure which one yet though. I'll either get a 4300k or 5000k HID kit for it. The 4300k would be a bit brighter, but would have more yellow tint than the 5000k. Since these are fogs, the beam pattern is low and wide so won't blind or effect oncoming drivers. They also have a shield similiar to HID projectors to give a nice clean cut-off. Should look good and be beneficial with my retro HID projectors when I get them installed.
Old Jan 24, 2008 | 01:05 PM
CLin9383's Avatar
Dont forget the writeup boys! Im looking to add fogs, but I may as well go HID!
Old Jan 24, 2008 | 02:01 PM
pfdaxe's Avatar
Not too much to write about. Your remove the halogen H3 and bulb holder and install the HID bulb. Here's some pics:
http://www.hidplanet.com/forums/view...ighlight=micro
Old Jan 24, 2008 | 02:28 PM
GOH10 Runner's Avatar
Brian, if that one fits and you keep it....wanna sell me one of your stock ones, mine just broke.
Old Feb 28, 2008 | 09:07 PM
UNR.Grad's Avatar
Where did you get your kit from? Thanks!
Old Feb 29, 2008 | 02:55 AM
pfdaxe's Avatar
....from another YT member that was selling a set....
Same as these:
http://www.yellowandbluelighting.com...3/Default.aspx
Old Feb 29, 2008 | 07:16 AM
UNR.Grad's Avatar
I was talking about th HID kit, my fogs are still decent... Thanks for the help!
