Disable rear heat - 3rd gen
Old Feb 1, 2008 | 07:36 PM
cbrew325's Avatar
Our 97 4runner has a hole in one of the hard lines feeding the rear heater core. Seems to be a common problem from what I've seen on the board. Can someone tell me what the steps are to bypass the rear heater?
Also has anyone replaced one of these hard lines? Was it very difficult? I'm guessing its probably not a cheap part from the dealer.
Old Feb 1, 2008 | 08:24 PM
DeathCougar's Avatar
If you dont mind a little driving I have all the pieces that you would need for rear heat. Come on up, and I'll just give them to you.
Which hardline is leaking?
Old Feb 1, 2008 | 08:33 PM
cbrew325's Avatar
The line nearest the middle of the engine bay. Thanks for the offer, but I don't think I am feeling like a drive to Washington tomorrow.
Old Feb 1, 2008 | 09:13 PM
well if you change your mind, the offer is open. Ill have the parts for a few more weeks.
Old Feb 2, 2008 | 08:19 AM
eric-the-red's Avatar
If you can get to the hard line cut out the leaking bit and put a piece of rubber heater hose in the gap, clamped at both ends. There's not a lot of pressure in the heater system so it should hold.
Old Feb 2, 2008 | 05:17 PM
MTL_4runner's Avatar
Just need to watch out near the exhaust, rubber will melt.
Jun 1, 2021 01:51 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
tpd143
Jul 7, 2015 09:06 AM
