Rear window problem
Old Jan 22, 2008 | 02:20 PM
Rear window problem
Hi
After fiddleling around the with re-inserting my clutch pedal return spring I lost the ability to roll up and down the back/tail gate window with the switch located over the radio. I did take off the the kickpanel near the clutch pedal but didn't remove any wires during the clutch pedal "fun".
The window still works if I use a key in the backdoor lock. The other windows seem to work fine. Also for the time I have owned my rear defroster haven't worked (are they linked?) but the window did until yesterday. Now I notice the brake light on the top of the back door is out too (could be a blown bulp).
Is there a fuse that controls this I could have blown, or am I having several unrelated electrical issues?
Any help is greatly appreciated.
Nevermind, I found out I had bumped the window lock button that I didn't know affected the rear windows button differently - ARGH.
Mods you can delete this thread if you like
Old Jan 23, 2008 | 06:46 AM
Smokey's Avatar
Speaking from experience, make sure you did not hit the window lock button on the driverside door. I freaked out awhile back when I tried to roll down the back window only for nothing to happen. I even began the process of making an appointment at the dealership to have it looked at; only to realize that no other window would roll down, and then it hit me...I had pushed the window lock button a few weeks prior.
Hopefully its something that easy for you too. Good luck!
Chris
Old Jan 23, 2008 | 09:16 AM
I edited my post. It was only the window lock button
Jun 1, 2021 01:51 PM
icentropy
Jul 11, 2015 07:21 AM
Jnkml
Jul 6, 2015 01:20 PM
coryc85
Jul 6, 2015 04:07 AM
