Low idle and engine stall
Old Aug 24, 2009 | 12:41 PM
pius222's Avatar
It's lunch time, went out to start my 4Runner, won't start, it fires up, but stalls. If I step on gas slightly, engine won't die, but as soon as I let the gas pedal go, the engine idles low and dies. No CEL light. This morning when I go to work it was fine.
I searched a little bit, found this point to the MAF, IAC, throttle body:
https://www.yotatech.com/forums/f2/3...-stall-186064/
but I had them serviced at the dealership:
https://www.yotatech.com/forums/f2/s...ership-126167/
What else could be the problem?
Tks
Old Aug 24, 2009 | 12:55 PM
Godzilla's Avatar
Ouch. $90 to clean a MAF, and 159 for throttle body service? You got ripped.
...Anyways, you will be throwing a MIL soon. If you do not, verify that your light is functional. It does sound like it is a IAC or MAF.
Old Aug 24, 2009 | 09:31 PM
DailyDrive's Avatar
Unplug MAF, it will go into failsafe mode. If it becomes drivable, there is your problem.
Old Aug 29, 2009 | 11:45 PM
pius222's Avatar
When I went home that day, the truck still won't start, but when I turn the key for a longer periods of time or step on gas hard (Don't know exactly which). The truck mysteriouly started and never fail again. However, I still followed the instruction and bought some TB and MAF cleaner and cleaned my TB and MAF just for peace of mind.
Old Aug 30, 2009 | 08:38 AM
ozziesironmanoffroad's Avatar
sounds like MAF...
Old Aug 30, 2009 | 09:17 AM
rdrttoy's Avatar
my truck did basically the same thing but my tps came un plugged. but im sure you have checked that allready
Charecter1
Nov 6, 2023 10:08 AM
icentropy
Sep 16, 2020 02:47 PM
steve miller
Oct 10, 2015 01:40 AM
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
