Control arm bushings and ball joints
Old Sep 5, 2009 | 01:24 AM
BajaRunner's Avatar
well my lower control arm bushings and ball joints are shot....... anyone replace these?
Old Sep 5, 2009 | 08:42 AM
MillerPKA's Avatar
Its time for some total chaos replacements
Old Sep 5, 2009 | 10:42 AM
BajaRunner's Avatar
...I couldn't find any on their website for the lower arms? I also couldn't find the ball joints.
How hard is it to press out the lower joint? I'm assuming I'll need to take it to a shop. How hard is it to replace the control arm bushings?!
How come whenever I ask a question on this forum I never get any answers!?
Old Sep 5, 2009 | 10:46 AM
SnowRunner98's Avatar
is the lower BJ's?? I think they are about 70 a piece like a 14mm four bolts. .
Old Sep 5, 2009 | 10:55 AM
http://www.extremehowto.com/xh/artic...ticle_id=60227
hope this gets ya started. uppers, you need that press out kit from any part store. you can rent one, and make sure you have air. I used the slug adapter/ ball joint removal tool from TC.
control arm bushings i'm clueless.
Old Sep 5, 2009 | 12:17 PM
desertcamper67's Avatar
Do you have access to an air compressor? I can help. I live in N. County.
Can I see a picture of your lower control arm/ball joint area?
Old Sep 5, 2009 | 01:00 PM
scuba's Avatar
LCA bushings are apparently a big PITA.
They need to be pressed out and pressed in.
Don't go poly just get oem rubber.
Or swap them out for some lower mileage LCA's
http://ttora.com/forum/showthread.php?t=140034
Old Sep 5, 2009 | 02:19 PM
Doublewid3's Avatar
The balljoints are a PAIN! All 4 of mine went out in a 1 week span also ripping my CVs. cost me $720 for all 4 and 2 cvs. Ya go with something designed for abuse.
Old Sep 5, 2009 | 04:17 PM
BajaRunner's Avatar
The guys at the alignment shop, who are known to be some of the best in SD County, (East County Alignment) told me that my lower pass ball joint need to be replaced and the LCA bushings needed to be replaced before I could even get an alignment. Annoying.
Thanks for those links.
DesertCamper...I live in Solana Beach, where abouts are you? No, no more air compressor for me.
Looks like finding some newer, used LCA's will be the way to go! Of course I sold my "spares" 2 years ago....
Old Sep 5, 2009 | 09:35 PM
I'm up in Bonsall just north of Vista next to Oceanside. We could do this. I just looked under my roommates '98 4Runner to get familiar with that particular type of ball joint and it looks like a piece of cake.
Try "mini trucks" off of Newton ave. down by the Coronado bridge. They usually have plenty of Toyota's. Good source for your LCA's
East County Alignment is a good shop. I used to work at Beeline in Pacific Beach.
I have access to an air compressor in Ramona. I wouldn't mind trying the bushings too. If you have a lot of rust, from living by the beach, you might want to get some replacement cam bolts for it before we start. If you do get arms, try to get the cam bolts with them. The yard may just cut them out so you'll have to request them.
Old Sep 6, 2009 | 09:11 AM
BajaRunner's Avatar
Thats funny, I was just in Bonsall yesterday picking up a MTR
I'll PM you.. .
Old Jan 4, 2010 | 10:35 PM
SharpStick's Avatar
Look at the author of the fix-it article. Used to work with him.
How'd it turn out?
STICK
Old Jan 5, 2010 | 07:20 AM
BajaRunner's Avatar
Well, this is what i did:
Bought lower mileage LCA's from DeathCougar (Josh) from Nix99. They had great bushings, and I decided to get brand new ball joints from NAPA. ($80 each).
I also bought a newer steering rack from DeathCougar.
Then I bought the Bilstein 5125 shocks and new Tundra coils from Sonoran Steel.
I just got back from a week in Baja and the ride was great, and the 400 miles on the twisty highway was good. The 100 miles offroad was great as well.
I am still getting a large CLUNK from the front on certain bumps (Usually at higher speeds, with an abrupt incline of the terrain). I cannot replicate it all the time. It must be something else. (No sway bar has been installed).
Next up are the Upper Ball joints, and after that, I am pretty unsure what else I could possibly replace.
Sep 4, 2015 09:27 AM
nick9455649
Aug 29, 2015 02:08 AM
yoder519
Aug 17, 2015 07:12 AM
kirkrunner
Jul 27, 2015 07:59 PM
ksmudrunner99
Jul 21, 2015 05:33 AM
