Electrical Solutions
Old Jun 13, 2005 | 12:22 PM
Noel's Avatar
Electrical Advice?
After hooking up my 240 Blitz lights my interior lights as well as all the exterior lights dim pretty badly. When I accelerate everything will brighten up. I have a 96 ltd with 2 lightforce, plan on adding a warn 8000, and I have about 1500 watts worth of audio gear. Can someone recommend a good electrical upgrade that would solve my problems? TIA
Old Jun 13, 2005 | 02:26 PM
Ironmike4x4's Avatar
Upgraded alternator or optima battery *maybe even dual optimas but I'm not too familiar with it*
Old Jun 13, 2005 | 02:45 PM
Noel's Avatar
i saw that thread and thats what sorta spawned this thread. should i get a yellow top and upgrade the alt or do a dual battery set-up. What are some good alt upgrade kits?
Old Jun 13, 2005 | 02:46 PM
msw0085's Avatar
yeah, you are def overloading the alternator with that much load, as is evidenced by the lights brightening when you accelerate. Capacitors, optima, probably both would be beneficial. Im sure an electronics guru will chime in with more detailed suggestions...
Old Jun 13, 2005 | 02:52 PM
Noel's Avatar
thanks msw0085...i have a 1 farad cap...what to do what to do
Old Jun 13, 2005 | 05:48 PM
Why would he need a compacitor? All it does is store the voltage not supply it. I can see him using one if he had a system in the truck for the low hits. You might be better off doing a search on it since it's been covered a bunch before. As far as alternators, the 3rd Gens usually talk about putting an MR2 alternator on since it has more amperage and bolts right up as far as i know of. I'm contemplating one myself for mine. Or just recently there is a thread about a dual battery setup. Check in there or search dual battery.
Old Jun 14, 2005 | 09:14 AM
Noel's Avatar
Ironmike...do you know the spec on the MR2? Like which model does that alt come from and what is the output? thanks
Old Jun 14, 2005 | 10:35 AM
Flamedx4's Avatar
Agree with IronMike, you need more supply not more storage. More battery only prolongs the issue. Upgrade the alt or turn off some stuff!
Old Jun 14, 2005 | 10:57 AM
Noel's Avatar
but i like all my stuff on. Is the MR2 Alt decently inexpensive?
Old Jun 14, 2005 | 11:15 AM
sefus's Avatar
I just did a new stock alt and Im wishing i had have upgraded. with my cd player, lights, tach, and electric fan on there is a big dim.
Old Jun 14, 2005 | 11:21 AM
Noel's Avatar
http://catalog.drivewire.com/drivewi...art=Alternator
is this the one...it only says 100amps and I thought I read somewhere on this forum that the MR2 had a 170amps *
"Get an alternator from a 91+ MR2 the one with the electrohydrolic power steering. Make sure you specify tha you MUST have the one for the power steering model.
Those beasts are 170AMS!!!
It bolts up (to the 5VZ) but you may have to change the pully though. Im running the MR2 crank pully too so im not sure if the mr2 alternator pully would line up.
Go to autozone and order a remanufactured one. Even if you dont trade your old one in for the core you will still save at least $200
Cheers
Jim"
Anyway, if it is a 100amps will that make a large difference over the stock alt I currently have?
Old Jun 14, 2005 | 04:35 PM
Yeah I was wondering that myself Noel. I am really not sure about what the true amperage is though. The only other problem I can see with the MR2 alt. is the connectors. I have not really researched it much yet so I don't know. Yes it will make much more differnce over stock since I think ours is only like 60 amps max amperage.
shooter86314
Jan 7, 2016 07:05 AM
Obmi
Oct 4, 2015 11:30 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
voiddweller
Sep 28, 2015 11:21 PM
Project90
Sep 24, 2015 11:40 PM
