LS & BPV Adjustments
Old Jun 16, 2005 | 04:58 PM
Ironmike4x4's Avatar
My front brake pads have worn out within a year of replacing and resurfacing the rotors. I am not using those cheap organic pads so don't ask about that. I used semi-metallic brake pads so they should last much longer than a year or 10K miles on them. My next thinking is my rears are not adjusted right and I checked, but they were snug so my next guess is the LS BPV. I was on alldata at work today trying to figure out how to adjust the Load Sensing and Brake Proportioning valve (LS & BPV) but the intructions are not clear. Can someone help or send a link to somewhere? Thanks!
Old Jun 16, 2005 | 05:37 PM
superjoe83's Avatar
to be simple, the farther you adjust the rod up to the body = more pressure to rear brakes
Old Jun 16, 2005 | 06:24 PM
Thanks! A direct answer that I needed.
zytra
Jan 24, 2019 03:16 PM
ZGjethro
Jun 7, 2017 11:04 PM
the_supernerd
Oct 1, 2015 09:20 PM
dbollier123
Sep 29, 2015 05:23 PM
moparbay
Sep 3, 2015 12:48 PM
