Need some advice
Old Jun 14, 2005 | 04:10 AM
defigh's Avatar
Need some advice
I searched but couldn't find what I was looking for...
I have a bit of a sag in the back of my 88 Runner and I'm looking to fix that. Would these do the trick? http://store.summitracing.com/defaul...Ntt=add+a+leaf
I am going to be looking to lift it before too long, so should I just go for the lift now, or the AAL?
I am going to be wanting a ~2" lift-any opinions on the best place to find one?
thanks for the help.
Old Jun 14, 2005 | 10:49 AM
Flamedx4's Avatar
The AAL will make it ride rough, especially on a short wheelbase light rig. I did that initially with my '85 Runner and will never use AALs again. Live with it until you do the lift.
Old Jun 14, 2005 | 11:16 AM
Fahrenheit 451's Avatar
I'll second that. Stock 4Runner rear springs are crappy enough to begin with. No point making a bad problem worse.
If you are doing a lift soon, go over to Pirate4x4 and search the Yota boards for the 63" Chevy 2wd rear leaf spring swap. Good lift, nice ride, flexy.
Someday when I have the bizarre convergence of time and money, I'm going that route.
Old Jun 14, 2005 | 11:24 AM
montypower's Avatar
Add some shackles... easy to install... and can give the little more lift you want.
Marlincrawler has em: http://www.marlincrawler.com/shackles.html Around $70
Remember for every 1" longer the shackle is... you will gain .5" lift. So a shackle 2" longer than stock will give approx 1" lift. Hope that helps.
Old Jun 15, 2005 | 03:46 AM
defigh's Avatar
Thanks for all the help. I think I am going to go with the shackles...easy fix and I can still use them once I decide on a lift.
thanks
ashamsuddin
17
Jul 22, 2024 03:59 AM
Steven.m.paulk
Jun 7, 2020 10:45 AM
hiluxinargentina
Sep 30, 2015 11:12 PM
charlie_fong
Sep 27, 2015 10:06 PM
taraf
Sep 25, 2015 02:57 PM
