AC Question
Old Jun 29, 2013 | 11:28 AM
link434's Avatar
Red face AC Question
Just finished swapping a bad compressor, started it up turned on the ac and nothing. Checked the wire connected to the compressor and it's not getting any power. The light on the ac button stays lit on green, and I checked the fuses which are all fine. It's just not getting power, any ideas what it might be?
THanks
Old Jun 29, 2013 | 12:10 PM
tantacoma's Avatar
Low refrigerant could cause that symptom
Old Jun 29, 2013 | 12:37 PM
link434's Avatar
How would that cause this problem? I don't think their's a sensor that monitors the refrigerant amount in it.
I haven't filled it up yet, I was gonna do that next but since it doesn't work at all I wanted to fix this first.
Old Jun 29, 2013 | 12:52 PM
link434's Avatar
I just added some from a bottle I had laying around and it turned on! thanks tanacoma
Old Jun 29, 2013 | 12:56 PM
swampfox's Avatar
deleted
Old Jun 29, 2013 | 02:29 PM
tantacoma's Avatar
Yes, there IS a sensor.
I'm glad it was just that simple for you.
Old Jun 30, 2013 | 04:43 AM
Keith122's Avatar
Did you evacuate the system before adding the refrigerant?
Old Jun 30, 2013 | 06:50 AM
pcola's Avatar
on my 88 single cab 4x4 the pressure sensor in under the kick panel on pass. side mine blew while waiting in line to get food lol i thought i'd blown a coolant hose but nope a/c pressure switch cost me all of $9.00 bucks but the best part was i already had the whole dash out redoing the dash and well heck i ended up repainting/covering anything that needed TLC. i am running the 22re and dont get me wrong its a great motor and would prob run on 2 of the 4 cylinders if need be. i k ow when i bout mine i thought damn this thing is slow until i seen #2 cylinder had all of 60psi on a good day wet or dry test... while 1,3,4 was around 160psi... its all fixed now but if i had know then what i do know i would have pulled the 22 sold it and would now be cruising with a non vortec GM 4.3!!!! 3 times the power and around the same cost. motor fits like a glove and i could still use all of my drive train.... ya live and ya learn
o and i had to use a 90 a/c fitting when i installed the ac on mine, it made it sch easier to charge and get at... well good luck buddy
Old Jul 2, 2013 | 08:44 AM
stophammertime's Avatar
Low refridgerant = low pressure = no AC for you. Glad you got it fixed.
lectric80
Aug 11, 2015 12:02 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
