Instrument panel lights
Old Jun 23, 2013 | 06:27 PM
kt19's Avatar
2002 4Runner SR5
The instrument panel lights (only the tach and speedo) are not working. I verified all the fuses were good. My tail lights are working. Also the license plate lights are not working.
Most logical would be a fuse but all are good.
Anybody had this issue.
Thanks
Old Jun 23, 2013 | 06:37 PM
rworegon's Avatar
Burned out bulbs? A trailer wiring kit doing weird things? You checked fuses under the hood and the in-cabin driver side fuse box fuses for continuity? Sometimes a visual inspection does not reveal a bad fuse.
Old Jun 23, 2013 | 06:57 PM
kt19's Avatar
Yeah used a meter to verify the fuses. Could be burned out bulbs but all at once seems odd. I was hooked up to a trailer recently but all of those lights seemed to be working properly. I will verify that again though.
Old Jun 24, 2013 | 07:53 AM
TheDurk's Avatar
Does rheostat bring other lights up and down? If not, investigate a possible problem there. Our trucks are at the age where those things start to go.
Old Jun 24, 2013 | 08:10 AM
kt19's Avatar
That is working as it should.
Old Jun 26, 2013 | 05:16 AM
kt19's Avatar
Looks like it might be all the bulbs burned out. Pulled the 2 for the license plate and both burned out and 12 volts in the socket. Have'nt had a chance to open up the dash yet but I will have bulbs on hand.
Wonder if it took a surge somehow.
gary4runner
Sep 24, 2015 12:53 AM
AkitaDog
Sep 1, 2015 08:05 AM
TDonkey
Jul 26, 2015 10:14 AM
rushw
Jul 18, 2015 01:46 PM
Jake28296
Jul 12, 2015 10:15 PM
