1999 4runner Fuel Injector
Old Jun 24, 2013 | 06:16 AM
hardiek's Avatar
I have a 1999 4runner where one of the fuel injectors is leaking gas. I replaced the o-rings and it still leaks gas. I check them and they are not pinched. Its hard to tell where exactly its leaking, but the gas is near the base as it is inserted into the piston.
Any ideas what else it might be? Can an injector go bad that would cause a gas leak?
Thanks.
Kevin
Old Jun 24, 2013 | 08:39 AM
crazypaint's Avatar
Might be bad. If u find out u need another one let me know I have 6 used but good extra they have 78 k on them
Old Jun 27, 2013 | 07:44 PM
hardiek's Avatar
Replaced all 3 injectors on the drivers side and no leak at the injectors.
Now its leaking gas at by the bolt connected to the front of the fuel rail. The bolt is tight; what else could it be?
Old Jun 27, 2013 | 08:13 PM
rworegon's Avatar
Leaking from the crossover pipe? If so, you not get the two metal gaskets back in on each side?
Old Jun 28, 2013 | 08:33 AM
hardiek's Avatar
I'll check the gaskets again.
Does crossover pipe connector screw hole need to line up exactly with the crossover pipe when it is installed? Or it doesn't matter?
Kevin
Charecter1
Nov 6, 2023 10:08 AM
steve miller
Oct 10, 2015 01:40 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
cyclist231
Jul 7, 2015 12:56 PM
karbin
Jul 5, 2015 11:37 PM
