overheated disc rotors
Old Jun 13, 2013 | 06:13 AM
KZN185W's Avatar
a friend of mine had a pair of slotted rotors (DBA 4000 series). His front brakes seized so on the way home, he traveled with the front brakes locked. As a result, the three thermo-graphic heat paint stripes (Green, Orange, & Red) turned to white, meaning the temperatures reached or exceeded 630 deg C / 1166 deg F.
my question now is would it still be safe to continue using the rotors? The brake pads have been replaced already.
Thanks!
Old Jun 13, 2013 | 12:52 PM
wyoming9's Avatar
Red face
As long as the front end does not shake apart.
What I would worry more about is how that heat effected the wheel bearing grease
I have seen tires blow from getting the brakes to hot back in the day of tube type tires.
Old Jun 13, 2013 | 05:24 PM
KZN185W's Avatar
good point on the grease wyoming9!
Thanks!
<img id="ums_img_tooltip" class="UMSRatingIcon">
Old Jun 13, 2013 | 07:41 PM
DRCOFFEE's Avatar
If the temper is lost and the discs are now more brittle, it seems to be an unwise risk considering the fronts do 80% of the braking. Toss them in the garbage.
Old Jun 13, 2013 | 10:17 PM
dropzone's Avatar
Fossilized
^^X2 don't skimp on your brakes
Old Jun 13, 2013 | 11:38 PM
wyoming9's Avatar
Red face
Me I myself would of changed all the front brake parts pretty much to me new pads new rotors
Depending just how they were cooled if they just were air cooled that little amount of heat would not effect the temper.Now if they were sprayed with the hose different story.
It is how things are quenched that effects the temper.
but would most likely have warped them so bad the shaking would bounce the coffee out of a 1/4 full coffee mug
Old Jun 14, 2013 | 07:19 AM
KZN185W's Avatar
the owner said that he left the brakes to cool by air, no water. he also said no warping as he brought it to a machine shop to be resurfaced. the machine shop guy told him no need to resurface as both rotors were ok.
TheBFA
Feb 15, 2020 06:55 AM
alexcarey
Oct 14, 2015 06:05 PM
the_supernerd
Oct 1, 2015 09:20 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
toyotasaurus
Sep 24, 2015 03:30 PM
