If only one grease
Old Mar 20, 2014 | 06:26 AM
Up&Down's Avatar
If only one grease
If you had only one grease gun, what cartridge would you put in it? Is there an all-in-one grease? The thing I grease the most is ball joints. What's the best grease for that?
Thanks.
Old Mar 20, 2014 | 06:41 AM
jbtvt's Avatar
For the extra $1 a tube I think the higher temp rating of moly grease is worth it. That's my all-in-one, good for guns too.
I stayed in Orono last year, beautiful area!
Old Mar 20, 2014 | 06:53 AM
Up&Down's Avatar
jbtvt,
Thanks for the word. If you're in Orono again this summer (if it ever arrives), send me a message and we'll get a beer and talk Tacos. I'll just whine about wanting a V6 4x4.
Old Mar 20, 2014 | 07:01 AM
Nelsonmd's Avatar
http://www.toyota-4runner.org/3rd-ge...ing-guide.html
Agreed, I'd go with Moly.
Old Mar 20, 2014 | 07:35 AM
Robb235's Avatar
KY jelly.
Old Mar 20, 2014 | 09:27 AM
Roark's Avatar
Originally Posted by Robb235
KY jelly.
..wut
Old Mar 20, 2014 | 01:36 PM
Nelsonmd's Avatar
From my link above...
Originally Posted by bikerjosh
So are you saying I shouldn't be loading all my zirk fittings with butter flavored crisco? Always makes me hungry when I get out the grease gun.:peace:
BTW-thanks for the post.
Old Mar 20, 2014 | 03:18 PM
wyoming9's Avatar
Red face
I have 5 or 6 grease guns and can never find the one I want.
I swear they have their own Social lives.
Old Mar 20, 2014 | 04:43 PM
Keith B.'s Avatar
I settled on moly grease long ago. Ball joints and certain u-joints require it, and over 16 years and 4 Toyota 4WD vehicles there's never been a problem. Currently have Valvoline Synpower in the grease gun, one of the few "synthetic" greases that has moly.
Old Mar 20, 2014 | 06:21 PM
lobukbuild's Avatar
moly is it, but regular any kind of grease is better than no grease.
Old Mar 21, 2014 | 09:11 AM
wyoming9's Avatar
Red face
Sometimes the wrong grease is much worse then no grease.
Old Mar 21, 2014 | 10:10 AM
Nelsonmd's Avatar
Not really. If there is no grease in the joint, adding any grease is better than letting it go with no grease. Pretty much any grease is better than letting them go dry. Even buttery crisco is better than dry.
There is a pretty good episode of vice about an african trucking company where the drivers, if they lose their gear oil, they stuff bananas in the diff. Any lube is better than no lube.
If you are just low on grease, and add an incompatible grease, then yes, you can make it worse, but if the joint is already washed out of grease, then anything is better.
Old Mar 21, 2014 | 11:43 AM
Rowdydudeman's Avatar
where i live, anytime one goes wheeling it's going to be a very moist experience. so i use marine grease.
Old Mar 21, 2014 | 01:09 PM
Swimmerboy2112's Avatar
I also use marine grease seems to work well.
Old Mar 21, 2014 | 01:35 PM
Yep, I've yet to have any failures with it.
Do you re-grease after every trip wheeling?
Old Mar 21, 2014 | 02:17 PM
Nelsonmd's Avatar
You're supposed to re-grease the drivetrain every time you go into water or the mud. Or technically if it rains much. Marine grease may last longer, but you should still grease it regularly.
Old Mar 21, 2014 | 02:26 PM
Of course one is "supposed" to. Lol
Hell, sometimes I re-grease after a long Sunday drive! Grease is much cheaper than failed tierods. Am I right? XD
Old Mar 21, 2014 | 08:47 PM
Keith B.'s Avatar
The same as with motor oil. The most important thing is that it has oil in it. Exactly what type of oil is the second choice.
Old Mar 22, 2014 | 02:34 PM
DRCOFFEE's Avatar
THE RIGHT ONE!
You were probably the PO of my 4runner.
Old Mar 22, 2014 | 02:41 PM
lobukbuild's Avatar
absolutely! after being upside down for a while and loose most of your oil and have to borrow 3 or 4 different qts. off your buddies ill use anything to get it topped off. even a little gear oil helps bring the level up.
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
pickle6415
Oct 19, 2015 08:08 AM
4Xtruck
16
Sep 24, 2015 09:38 AM
Peevedkitten
11
Aug 31, 2015 06:57 PM
