Spark plug popped out
Old May 18, 2014 | 07:24 PM
808toys's Avatar
I have a 99 tacoma 3.4L engine. My number 3 spark plug already had a heli coil . Well it popped out and now the #3 hole is to large to put another one in. What is my options now?
If i need to change my head what else would be wise to do to it,like replace water pump,belts,gaskets etc. Thanks
Old May 19, 2014 | 06:00 AM
Jomoka's Avatar
Timing belt, tensioners, etc. I probably wouldn't bother pulling the other head and swapping the HG unless it looks pretty gnarly on the head you have to pull. But if it looks iffy, you're already mostly there.
Old May 19, 2014 | 09:43 AM
808toys's Avatar
good to know. now to find a head. Thanks
Old May 19, 2014 | 02:49 PM
rworegon's Avatar
Replace the knock sensor wire. They get incredibly beat up by the heat. Oh, and reseal the coolant bypass tube. I'd not be surprised if you find some coolant in the valley between the heads.
Old May 21, 2014 | 01:31 AM
808toys's Avatar
will check on those issues. Just got a rebuilt head from reman heads and getting ready to change it. Can anybody give me some good tips for changing them out! would greatly be appreciated
Old May 21, 2014 | 02:52 PM
rworegon's Avatar
Your mileage may vary, but these may be helpful:
http://home.centurytel.net/stevenjac...lt/timing.html
http://www.ultimateyota.com/showthre...ght=overheated
Oh, yea...the t-stat jiggle valve goes in the 6 o'clock position.
Eggslinger
Jun 8, 2019 03:32 PM
montanatruck
Feb 26, 2017 07:07 AM
raptor510
Feb 17, 2017 07:11 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
cars-guy
Jul 11, 2015 07:51 PM
