Misfire after rain
Old Apr 8, 2014 | 04:06 AM
Up&Down's Avatar
Misfire after rain
So after a good rain, the Taco cranks up fine and idles fine. But when I give it some throttle it runs really rough- skipping basically.
The first time it did this the check engine light started flashing.
After it warms for a bit it all smooths out.
What's the culprit on this?
I just bought new plugs, cap, rotor, and wires to replace when I do a valve clearance check.
Also, what's the difference between a flashing check engine light and one that just stays lit.
Thanks all.
Old Apr 8, 2014 | 04:09 AM
turkeykiller365's Avatar
flashing CEL usually means mechanical failure such as a misfire. In other words it means bad news. Check your o2 sensors
Old Apr 8, 2014 | 04:11 AM
uhh actually if you have a mechanical distributor idk how an o2 sensor would cause a misfire. my chevy did that once. Computer changed the timing for bad air/fuel mix
Up&Down's Avatar
turkeykiller365,
Thanks for the reply. I figured a flashing CEL was worse. Just replaced O2 sensors (front 10K ago and back 1K ago). CEL stopped flashing when I cranked it back up. Scanned for code and it was misfire on Cyl 3. Cleared it and it hasn't come back.
Is there a way for water to get into the distributor, etc.?
Old Apr 8, 2014 | 04:18 AM
yeah. we had that happen to a jeep once but it had had like 3 cups of water in the intake plenum. ie, there was water in everything. It didn't run at all. An air flow sensor might cause it too. no idea what kind of airflow sensor a 2RZ has. if its a hotwire one, theyre very sensiotive
shooter86314
Jan 7, 2016 07:05 AM
calderp
Nov 16, 2015 02:49 AM
the_supernerd
Oct 1, 2015 09:20 PM
shredder4286
Oct 1, 2015 01:09 PM
larrys93pickup
Sep 17, 2015 07:05 PM
